Grey heat resistant paint for stock exhausts
- Has thanked: 141 times
- Been thanked: 100 times
I'm looking for grey heat resistant paint that can be used for the stock look on Beetle exhausts. Does anybody know of a local (South African) source?
- Oil Seal
- Has thanked: 7 times
- Been thanked: 15 times
Re: Grey heat resistant paint for stock exhausts
Will this not work
VHT cans - available at midas
- Oil Seal
Looks like this one can handle higher heat
no it wont work, thats made for the exterior surfaces of an engine
500F is only 260degC, exhaust gas at idle is hotter than that
- Oil Seal
This is 1093 degC
This also looks like a good suggestion, assuming the exhaust doesn't get hotter than 1093 deg C. Thanks @spicydave. I'll check out my local hardware.
You'll probably find VHT at hardware stores and builders warehouse too
But I know for definite that Midas sells it - it was next to the VHT caliper paint I bought a few weeks ago
Thanks. I expect Midas to be the most expensive, but I'll have a look around.
