Tyre rubbing on suspension
Posted: Tue Oct 31, 2017 12:26 pm
Is this rubbing due to wheel size being bigger than standard or something else?
Forum for Aircooled VW enthusiasts
https://www.aircooledvwsa.co.za/
So what rims and tyres should I look out for that came on a 1971 1300 beetle to be originalfig wrote:Original 15in Rostyles have the same dimensions as the stock Beetle 15in rims. Some VWSA models (eg, 1600S and SP), had standard 14in Rostyles, with a wider offset. But be careful, as I have come across 14in Rostyle replicas that don't necessarily share the same offsets, etc
Stock Beetle 15in steel rims are known as "smoothies" because they have no slots in them, like bus rims do. These rims were fitted to Beetles from about 1953 right up to the end of production, so are easy to find. Size is 15x4.5J; I don't know stock offset, but I believe they're all the same. Stock tyres for these rims are 165x15 radials. Rostlyes first appeared on higher-spec SA Beetles in 1975.No More Landy wrote: ↑Wed Nov 01, 2017 11:18 amSo what rims and tyres should I look out for that came on a 1971 1300 beetle to be originalfig wrote:Original 15in Rostyles have the same dimensions as the stock Beetle 15in rims. Some VWSA models (eg, 1600S and SP), had standard 14in Rostyles, with a wider offset. But be careful, as I have come across 14in Rostyle replicas that don't necessarily share the same offsets, etc
Thanks for that. Makes it much easier to look now.fig wrote:Stock Beetle 15in steel rims are known as "smoothies" because they have no slots in them, like bus rims do. These rims were fitted to Beetles from about 1953 right up to the end of production, so are easy to find. Size is 15x4.5J; I don't know stock offset, but I believe they're all the same. Stock tyres for these rims are 165x15 radials. Rostlyes first appeared on higher-spec SA Beetles in 1975.No More Landy wrote: ↑Wed Nov 01, 2017 11:18 amSo what rims and tyres should I look out for that came on a 1971 1300 beetle to be originalfig wrote:Original 15in Rostyles have the same dimensions as the stock Beetle 15in rims. Some VWSA models (eg, 1600S and SP), had standard 14in Rostyles, with a wider offset. But be careful, as I have come across 14in Rostyle replicas that don't necessarily share the same offsets, etc
Best you can do is to take the tyres off, and take them to a rim repair shop, let them take the centers out and re-weld them in center of the wheel or a bit more to suit the car.No More Landy wrote: ↑Wed Nov 01, 2017 6:22 am Happens both sides but left side more.
I actually want to go back to original rims and tyres.
Is the rosta wheel the original rims that i often see advertised in classifieds?
I dont like the wide tyres or the current rims to be honest. I also notice the rear suspension seems lower than it should be so I would like to put that up to normal. Problem is my daughter does not like me to change her beetle as it means she is without her car fir some days.retrovan wrote:Best you can do is to take the tyres off, and take them to a rim repair shop, let them take the centers out and re-weld them in center of the wheel or a bit more to suit the car.No More Landy wrote: ↑Wed Nov 01, 2017 6:22 am Happens both sides but left side more.
Cost less then new wheels, and your old tyres will be usable.
Maybe be safe, and take the car their let them measure the off set and get it right 1st time.
OMO
