How to bend metal fuel line
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
So guys, how is this done correctly without stuffing up or pinching the pipe?
- Been thanked: 322 times
Re: How to bend metal fuel line
I just do it by hand. Carefully.
So long as you gently massage the bend and don't make the turns too tight, there's no need for special tools. Same applies to brake lines.
- Has thanked: 193 times
- Been thanked: 121 times
Adendorff sell a small hand tube bender for about R150 if you need tighter bends but like Fig says by hand if they are bigger radius bends.
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
plumbing benders also work
Old Toppies always said...
You bend over the thigh not the hand, and you will never kink the pipe.
