rear disc conversion
I know that I can use Golf GTI 1 or 2 rear disc's for this conversion but are there any other modifications that need to be done?
you need the hubs made up too and the mounting bracked
Handbrake cables as well, it is then a bolt on, BTW the disk used in the rear of the beetle is a solid Golf 1 front disk.
Calooker, can you supply the hubs and any made up parts needed for this conversion?
Yes give me a call.
Rui 082 830 6493
PhantomPhondler
What model do you have?: Puma
Post by PhantomPhondler »
rui's kit is good. got it.
car stops very quick. I bought calipers from volkspares, disks from goldwagen, brake pads, bearings, bolts etc from a spare shop in booysens. my only problem was that i bought the wrong size bearings, and that the handbrake cable had to be shortend cause I have a shortend chassis. otherewise all went sweet.
