Received fines and summons for car that is not mine
Eugene
Twin Port
Has thanked: 37 times
Been thanked: 43 times
Flag: Croatia
Post by Eugene » Tue Jun 05, 2018 9:17 am
As per the subject, I have received two fines and subsequently summons' for these fines. I refused to sign and the clerk noted on the summons that neither the car, nor the registration numbers belong to me. So how did they end up with me?
If you are in a position to extract owner information for a registration number, please PM me.
Has thanked: 224 times
Been thanked: 287 times
Flag: South Africa
Re: Received fines and summons for car that is not mine
Post by fig » Tue Jun 05, 2018 10:20 am
Cloned number plates or cloned identity.
FYI, you don't have to accept the summons for it to be lawfully served. It only has to be handed to a person over age 16 at your premises. You can always afford to ignore fines, but as soon as you know summons has been issued you must take action or risk a contempt of court charge and arrest. Your best response now should be to make a written repesentation to the prosecutor explaining why you are not liable, giving what documentary evidence you have. The case will likely be withdrawn then.
Flag: South Africa
Post by fig » Tue Jun 05, 2018 10:24 am
In December I got a camera speeding fine for a bakkie in PE that had the same Mpumalanga registration number as had been on a Mitsubishi L300 camper that I owned, although it got a new GP plate when I registered it in my name, so the old plate that got the fine had never been registered to me, and in fact I had sold the car the month before getting the fine. So it's not only criminals causing this chaos, it's incompetence by the authorities.
Has thanked: 152 times
Been thanked: 377 times
Flag: Netherlands
Post by retrovan » Tue Jun 05, 2018 10:44 am
This sounds like identity theft.
You will probably find the car is registered in your name, without you knowing it.
This is easily done with bent clerks in the lic dept.
So unless you can prove that you do not have the car, and never have, you will be held responsible for the fines.
So it you can not name the driver at that time, or prove you where some place else at the time, it will be hard.
Go to your lic dept, get a printout of cars on your name, and if something else is on there, apply for duplicate RC as quick as possible and scrap it, as you may get much more :bn: then you need.
Good luck
1968 Fastback 2Lt.type4( Red)
2019 MeFusco Beetle Truck
Flag: South Africa
Post by fig » Tue Jun 05, 2018 11:36 am
As much as this will cost you time and money, it's probably the simplest solution, followed by a formal charge of identity theft laid with the cops, to establish a paper trail to respond to any future fines, etc.
Merlin
Has thanked: 11 times
Flag: Germany
Post by Merlin » Tue Jun 05, 2018 11:42 am
I got a fine on one of my reg' plates a few years back. The problem was that whilst it was clearly my reg', it was affixed to the front of a Renault Scenic.
In all honesty, I was more perturbed about being referenced as the owner of a Renault Scenic than having my plate cloned. :mrgreen:
