"Eva-Ann"
buggyfan
Long Block
Has thanked: 82 times
Been thanked: 73 times
Flag: South Africa
Re: "Eva-Ann"
Post by buggyfan » Fri Mar 15, 2019 2:40 pm
:roll: Measure twice..... Cut once :roll: :roll:
Batman
What model do you have?: 1971 Beetle 1600 TP
Flag: South Africa
Re: "Eva-Ann"
Post by Batman » Thu May 02, 2019 6:48 am
Cut some new door cards yesterday ...
Terry Phillips
Has thanked: 161 times
Been thanked: 110 times
Flag: South Africa
Re: "Eva-Ann"
Post by Terry Phillips » Thu May 02, 2019 2:17 pm
Thats a step closer now keep the pictures coming in. :D
Oil Seal
Been thanked: 43 times
Flag: South Africa
Re: "Eva-Ann"
Post by Haans » Fri May 03, 2019 11:04 am
Looking good!,.....now try thecovering ,,....if younot to fussy with detail patterns,..youcan do it also.
Just take your time!,....and try the glue in a spraycan,.....seem to work well
Oh!!,...keep the car out the sun for at least a week once cards are fitted,....they say the glue must cure!!
Batman
Flag: South Africa
Re: "Eva-Ann"
Post by Batman » Fri May 03, 2019 12:47 pm
Luckily i'm going to get it covered by an upholsterer
Batman
Flag: South Africa
Re: "Eva-Ann"
Post by Batman » Tue May 14, 2019 6:33 am
Batman wrote:
Mon Dec 10, 2018 7:27 am
The previous owner rubberised the interior for some reason. I thought that it was still in a good condition and that I would just clean it out and I would carpet over it.
But the weekend with some closer inspection I realised that it was lifting and that the one door is leaking, causing water to build up between the rubberising and the floor-pan.
Glad to say that all rubberising has been removed. Now sanding and then some paint......
Batman
Flag: South Africa
Re: "Eva-Ann"
Post by Batman » Thu May 23, 2019 10:40 am
Some before work in progress photos.
Riaan.N
Been thanked: 18 times
Flag: South Africa
Re: "Eva-Ann"
Post by Riaan.N » Fri May 24, 2019 10:19 am
Also recently done the areas under the front and rear seats.... it looked as if the battery had a baby powder party
What size is the Willard battery you have?
Batman
Flag: South Africa
Re:
Post by Batman » Fri May 24, 2019 1:55 pm
647
Riaan.N
Flag: South Africa
Re: "Eva-Ann"
Post by Riaan.N » Sun May 26, 2019 6:09 pm
647
Thank you. Does it fit nicely? Do you use the original bracket and ‘dop’?
When the time comes I will be replacing my battery with something a bit bigger (Ah) and also if possible with the recessed terminals.
Batman
Flag: South Africa
Re: "Eva-Ann"
Post by Batman » Mon May 27, 2019 7:41 am
Did some cleaning the weekend ... and cut a new rear seat backboard
Batman
Flag: South Africa
Re: "Eva-Ann"
Post by Batman » Fri Jul 12, 2019 1:51 pm
Got some widened steelies for the rear ....
Batman
Flag: South Africa
Re: "Eva-Ann"
Post by Batman » Fri Jul 12, 2019 1:59 pm
Sorted prepping the pan ....
Riaan.N
Flag: South Africa
Re: "Eva-Ann"
Post by Riaan.N » Fri Jul 12, 2019 2:44 pm
You are making good progress and have put in a lot of elbow grease! :D
How was/is the condition of the pan halves?
Batman
Flag: South Africa
Re: "Eva-Ann"
Post by Batman » Mon Jul 15, 2019 6:36 am
Pan is actually good, just the usual part where the battery is, is a bit rusted. Will cut it out and replace the small section.
Must say a lot of elbow grease :D ... was a mission to get the rubberizing removed.
