Page 7 of 9
Re: "Eva-Ann"
Posted: Fri Mar 15, 2019 2:40 pm
by buggyfan
Re: "Eva-Ann"
Posted: Thu May 02, 2019 6:48 am
by Batman
Cut some new door cards yesterday ...
Re: "Eva-Ann"
Posted: Thu May 02, 2019 2:17 pm
by Terry Phillips
Thats a step closer now keep the pictures coming in.
Re: "Eva-Ann"
Posted: Fri May 03, 2019 11:04 am
by Haans
Looking good!,.....now try thecovering ,,....if younot to fussy with detail patterns,..youcan do it also.
Just take your time!,....and try the glue in a spraycan,.....seem to work well
Oh!!,...keep the car out the sun for at least a week once cards are fitted,....they say the glue must cure!!
Re: "Eva-Ann"
Posted: Fri May 03, 2019 12:47 pm
by Batman
Haans wrote: ↑Fri May 03, 2019 11:04 am
Luckily i'm going to get it covered by an upholsterer
Re: "Eva-Ann"
Posted: Tue May 14, 2019 6:33 am
by Batman
Batman wrote: ↑Mon Dec 10, 2018 7:27 am
The previous owner rubberised the interior for some reason. I thought that it was still in a good condition and that I would just clean it out and I would carpet over it.
But the weekend with some closer inspection I realised that it was lifting and that the one door is leaking, causing water to build up between the rubberising and the floor-pan.
Glad to say that all rubberising has been removed. Now sanding and then some paint......
Re: "Eva-Ann"
Posted: Thu May 23, 2019 10:40 am
by Batman
Some before work in progress photos.
Re: "Eva-Ann"
Posted: Fri May 24, 2019 10:19 am
by Riaan.N
Also recently done the areas under the front and rear seats.... it looked as if the battery had a baby powder party
What size is the Willard battery you have?
Re:
Posted: Fri May 24, 2019 1:55 pm
by Batman
Riaan.N wrote: ↑Fri May 24, 2019 10:19 am
647
Re: "Eva-Ann"
Posted: Sun May 26, 2019 6:09 pm
by Riaan.N
Batman wrote:Riaan.N wrote: ↑Fri May 24, 2019 10:19 am
647
Thank you. Does it fit nicely? Do you use the original bracket and ‘dop’?
When the time comes I will be replacing my battery with something a bit bigger (Ah) and also if possible with the recessed terminals.
Re: "Eva-Ann"
Posted: Mon May 27, 2019 7:41 am
by Batman
Did some cleaning the weekend ... and cut a new rear seat backboard
Re: "Eva-Ann"
Posted: Fri Jul 12, 2019 1:51 pm
by Batman
Got some widened steelies for the rear ....
Re: "Eva-Ann"
Posted: Fri Jul 12, 2019 1:59 pm
by Batman
Sorted prepping the pan ....
Re: "Eva-Ann"
Posted: Fri Jul 12, 2019 2:44 pm
by Riaan.N
You are making good progress and have put in a lot of elbow grease!
How was/is the condition of the pan halves?
Re: "Eva-Ann"
Posted: Mon Jul 15, 2019 6:36 am
by Batman
Riaan.N wrote: ↑Fri Jul 12, 2019 2:44 pm
Pan is actually good, just the usual part where the battery is, is a bit rusted. Will cut it out and replace the small section.
Must say a lot of elbow grease
... was a mission to get the rubberizing removed.
