Hi there, do beetle seats fit a variant 412? I'm looking at replacing my seats and would like to do it as a set.
Sent from my SM-G950F using Tapatalk
Do beetle seats fit a variant 412?
Re: Do beetle seats fit a variant 412?
your type 4 seats should be more comfortable then Beetle seats, from my experience.
Just have them re-upholstered with extra foam
OMO
OMO
would not know, as as far as I know the 412 seats are wider, so the rails would be too.
Me Thinks..
- mhsmuts
- What model do you have?: Variant type 4, 412
- Been thanked: 4 times
My front seats are non standard and although in great condition do not fit the look I am working on. Variant seats are difficult to find..
well in that case, you can take the rails off the existing seats and fit them onto the new beetle seats.
You may have to bend the leg tubes to the right width or weld a flat bar to the bottom 1st,
- Camshaft
- Been thanked: 107 times
What I do know is that a ghia pan and beetle pan is not the same,...ghia is apparently the same as Type 3 pan.
I measured ONLY after I off loaded a beetle pan at home !!!
....lesson was short but expensive !. The ghia that required this pan has since been moved on !
Thanks boet
Thanks boet
