Page 1 of 2
Acc pedal problems
Posted: Mon Aug 20, 2007 1:14 pm
by vader
Anyone got a fix for the dreaded rusted off Acc pedal? You know what I mean or must a draw a picture?
Posted: Mon Aug 20, 2007 1:49 pm
by natbro
I've got the same problem
Posted: Mon Aug 20, 2007 2:43 pm
by Chris
Just buy a normal hinge at a hardware shop and screw it on.
Posted: Mon Aug 20, 2007 3:15 pm
by fig
Chris wrote:Just buy a normal hinge at a hardware shop and screw it on.
That's what I've done; works great.
Posted: Tue Aug 21, 2007 7:00 am
by Pine
I put two (orange) roller blade wheels on the accelerator bracket to replace the pedal. It works like a charm, almost like the accelerator wheel of those old split/oval Beetles. The wheels roll under your foot when you step on the accelerator
Posted: Tue Aug 21, 2007 12:00 pm
by vader
Thats a good idea Pine but can you still "heel-toe"???
Posted: Fri Aug 24, 2007 11:21 am
by vader
So does this mean no one knows what "heel toe" is?
Posted: Fri Aug 24, 2007 11:33 am
by brianj
no old skool racers in the house?
Posted: Fri Aug 24, 2007 11:47 am
by Merlin
Heel-and-toe double-declutcher here.
Posted: Fri Aug 24, 2007 5:47 pm
by Bugger
Ya Normally Heel toe to make a burn out at the staging area
I have actuallu bought a golf one acc lever at the junk yuard and fits from the top now and a new cable from front to back
Will take a pic after feeling better ocured some 1st degree burns so it it ouch right now
Posted: Fri Aug 24, 2007 6:26 pm
by fig
Bugger wrote:Will take a pic after feeling better ocured some 1st degree burns so it it ouch right now
WTF did you do to yourself this time? Your guardian angel works overtime!
Posted: Fri Aug 24, 2007 8:52 pm
by Bugger
had a run in with my one trucks diesel tank had a leak and just started to tack weld and the fumes had a bark at me the boys had the truck standing in the sun the whole morning while loading and did not know, the fumes was obviously so hot (welded numeristimes on diesel tanks before with no problems) and whusssssssssssssssshhhhhhhhh
And again lucky me
The most impact was in my arm pit so that is eina
Posted: Fri Aug 24, 2007 9:58 pm
by Chris
Ei-f#cki-na!
Posted: Sat Aug 25, 2007 8:23 am
by Merlin
FARKN L!
You Nutter.
Posted: Sat Aug 25, 2007 9:53 am
by brianj
you wont have to shave your arm for a while at least!
