Universal fan mounting kit ??
Been thanked: 26 times
Flag: South Africa
Post by Haans » Wed Mar 13, 2019 11:16 am
All,..looking for similar kit as below,....mine is beyond salvage,.....yes as close to Pe as possible
Tried Plastic rebuilders and Wurth and Speedyquip ?
Please point me in the right direction!
Thanks. haans
Has thanked: 163 times
Been thanked: 394 times
Flag: Netherlands
Re: Universal fan mounting kit ??
Post by retrovan » Wed Mar 13, 2019 11:33 am
Silverton Radiators , 44 Slater St, North End, Port Elizabeth, 6001
Phone: 041 484 2510
1968 Fastback 2Lt.type4( Red)
2019 MeFusco Beetle Truck
Flag: South Africa
Post by Haans » Wed Mar 13, 2019 11:53 am
Thanks Herman,......it will bemy next stop tomorrow morn.
Flag: South Africa
Post by Haans » Fri Mar 15, 2019 8:02 am
Gave it up,..cannot find. It anywhere !!!
Back to drawing board
V6 Capri
What model do you have?: 1972
Been thanked: 13 times
Flag: South Africa
Post by V6 Capri » Fri Mar 15, 2019 8:36 am
They sell it up here in Gauteng for something like R50 each at Turbo Toys, which is down the road from where I am.
If you don't come right, and want, I can always send you a set or 2?
1964 Ford Anglia 997cc
1972 Ford Capri 3L GT
1996 Escort 2L Zetec
2016 VW Touran 1.6TDi
1971 Baywindow project
Flag: South Africa
Post by Haans » Sat Mar 16, 2019 8:53 am
Thanks boet,....no onePE seems to stock it,....even theguys that sell electric fans,......comes in the kit ! But not seperate.
Anyhow,..... Most of the guys I talk to puts me of this type of fastener,....... ".they" say it eventually causes a leak from vibration,.....rubbing through the cooling fins ? Don't know if it will be. One year or ten ?
So I'll be redoing my design
Thanks. Haans
Flag: Netherlands
Post by retrovan » Sat Mar 16, 2019 7:47 pm
What car is this for, surely its easy to get the shroud that fits to the radiator with fan attached.
If its for the 4 letter begin with F car, the Golf combination is cheap and easy to fit, and big enough for the f$%# motor.
By the way, do you live on Villiers road, with a kombi and beetle in the yard..... ??
Flag: South Africa
Post by Haans » Mon Mar 18, 2019 7:43 am
Retrovan,...nope not in Villiers ! The missus would have loved that!
The idea is to place an outside cooler in the ghia with a fan down next to the G-box ,....i.ve got everything. 230 x310 cooler,....
Take-off from the old "internal" cooler position.🛠
Yes!.....I've listened to all the advice given to me regarding a "remote" cooler,....but my gut tells me a remote cooler with a fan with a temp gauge and pressure gauge will sooth my "discomfort" in terms of keeping the engine cooler. With this I am not saying the Germans were not clever!!.....the advancement in technology has moved on with "improved" systems.
Feel free to convince me otherwise 🤔
Flag: Netherlands
Post by retrovan » Mon Mar 18, 2019 9:22 am
.......I am not saying the Germans were not clever!!.....the advancement in technology has moved on with "improved" systems.
No argument from me on that point.
What I have found easier, is to add to their systems rather then to replace it.
Thats why I fitted an extension sump from Volkspares, and a small scoop which I will later take off when she has fully run in.
The extended oil sump, gives extra cooling and reassurance that you have more oil in the sump so you will not run short on a long run.
By fitting a Oil temp gauge and a rev counter, I have learned that the aircooled motor cooling ability is best at 3000rpm.
The minute you get over the 4000rpm mark, the cooling/ heating ration goes to :bn:
Now when I work any of my aircooled hard, I take it back to 3000rpm, for a few minutes and it cools right down.
Hope you find what you are looking for.
Has thanked: 138 times
Been thanked: 387 times
Flag: South Africa
Post by Tony Z » Mon Mar 18, 2019 12:41 pm
what oil are you using?
Flag: South Africa
Post by Haans » Mon Mar 18, 2019 2:14 pm
Tony & Retrovan,...oil to be used?,......will check out some feedback,....some fancy shell product.
Engine is stock 1641cc with single port heads,..ran two years ago on a diesel oil,...with high 'heat' properties. So after startup I will drain and refill the system with something great that does'nt break the bank,..some 15/40 type
Ps fitting oil filter into the "system" as well.therefor think I will add at least 1.5 lt to the system,..cooler; pipes and filter
Who knows what I can scratch out ? Dual carbs?,.......better exhaust? ...homemade 'sebring' style?........you never know
Talk to me !
Just want to get it moving again !
Flag: South Africa
Post by Haans » Mon Mar 18, 2019 2:16 pm
Ps revcounter lying in waiting ,.....going into clock space,.....will show once calibrated
Flag: South Africa
Post by Tony Z » Mon Mar 18, 2019 2:33 pm
15W40 is a good viscosity to run and will keep the engine cooler than a 20W50 will.
My bus has a T1 engine (2110cc) and a T4 long ratio gearbox - thats the dreaded combo that kills T1 engines due to high load, and low rpm... running with 2L sump extension, Rimula R4X 15W40 oil and a few mods, the engine doesnt overheat - no filter, no extra cooler.
Your 1641 in your Ghia should not overheat ever with a stock cooling system, if it does, you have other issues
Flag: Netherlands
Post by retrovan » Mon Mar 18, 2019 5:54 pm
As Tony said 15W40 is perfect in a Diesel type of oil, for heat tolerance, do not go to these fancy chemical oils, they breakdown on heat.
Just remember you do want the oil to get to above 100 deg. C every now and then to steam off the water condensate that all engines make.
If not. you will get foam in your sump, and it will not be able to pump it through the engine.
So beware of over cooling.
Flag: South Africa
Post by Haans » Tue Mar 19, 2019 10:40 am
Thanks Herman,....the plan is to have the cooling fan on a relay through a switch in the cockpit,... so it can be controlled.
There is some or other electronic temp sensor control unit that can be put in-line and it will autmatically let oil run through the cooler above a certain temp,....BUT the budget is being watched as we speak!!!,..by you know who !!!😪🤒
Temp gauge is not negotiable !
Thanks for input
