Windscreen rubbers
Come talk £%$ with us.
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Windscreen rubbers
Post by Terry Phillips »
I had the hood lining done and 3 attempts later I got it back but now they ran out of material so they just added on a greyish material at the back so I said no enough is enough and left it like that and after looking at it a few times it starting to grow on me.
Now the next problem I got a imported windscreen rubber and got my old panel beater to fit the windscreen.But this one has the groove to take the beading,before fitting it he put those aluminium beading's in and fitted the windscreen but just as its all done the beading keeps popping out.Any advice on how to keep the beading in place.
I called PG to fit the beading and refit the windscreen R1800 if they come to me its R2500.
I watched You Tube and they make it look so easy,I cant attempt it as I will end up with a large fist going through the windscreen with my pain level so high from my back.
Does any one know what these guys are doing wrong. All the other windows went in no problems at all :oops: .
Been thanked: 100 times
Re: Windscreen rubbers
Your success is mostly dependent on the quality of the rubber. The rubber needs to be soft and the groove needs to grip the beading. Prior to installing into the car make sure that no part of the beading has popped out. The person applying pressure on the outside needs to continuously check that the beading is in place while the one on the inside pulls the rope. LOTS of diligence is required.
You could also tape the beading to keep it from popping out.
The trick is not to get any lubrication in the grove, then you will get the bead to popout
Try to clean the grove and the bead with an Mentholated spirits, and then only lubricate the car, and not the rubber
Works for me
Hope you come right.
spicydave
Oil Seal
What model do you have?: 1973
Has thanked: 7 times
Been thanked: 15 times
Post by spicydave »
Uncle @Terry Phillips
Contact GP Windscreens in Edenvale
They know their story with Beetle \ Kombi windscreens
