Upside down trumpets
brianj
What model do you have?: '67 DC, 66 Fasty
Has thanked: 11 times
Flag: South Africa
Post by brianj » Wed Apr 17, 2019 11:01 am
So I have these buggy trumpets.... has anyone ever flipped then over and swopped sides so they come out below the motor and in the centre? Is it possible?
The exhaust studs will line up, but not sure about other clearances..
edit - this on my early bay, which is riding high at the moment...
Sent from my SM-G973F using Tapatalk
For sale or trade...
- 59-67 bus engine lid
- slash bus front bumper
- 4-1 1600 exhaust, exit behind wheel arch, j pipes
- westy roof cot
acpaterson
Has thanked: 78 times
Been thanked: 124 times
Flag: South Africa
Re: Update down trumpets
Post by acpaterson » Wed Apr 17, 2019 11:04 am
if you look at the bottom pic, thats an approximate height where the engine usually sits. (The outlets). So the trumpets would essentially be dragging on the tar under normal conditions.
Im sure you could cut em and re-position to get them just below the motor itself, but for sure, you don't have much clearance under a stock motor ride height.
Al
Merlin
Been thanked: 38 times
Flag: Germany
Re: Upside down trumpets
Post by Merlin » Wed Apr 17, 2019 5:37 pm
Two thoughts...
1. You would have an uninsulated heat source directly below your sump.
2. Access to your sump plate will be next to impossible, making oil changes a nightmare.
brianj
Flag: South Africa
Post by brianj » Wed Apr 17, 2019 8:40 pm
Merlin wrote:Two thoughts...
Fair comments both...
- westy roof cot
Terry Phillips
What model do you have?: T3,58,60,61beetle
Has thanked: 155 times
Been thanked: 106 times
Flag: South Africa
Post by Terry Phillips » Thu Apr 18, 2019 1:27 pm
Price
brianj
Flag: South Africa
Post by brianj » Thu Apr 18, 2019 2:03 pm
800?
