Beetle 6V to 12V wiper motor conversion
Posted: Mon May 06, 2019 9:53 pm
by 73type2
Re: Beetle 6V to 12V wiper motor conversion
Posted: Mon May 06, 2019 10:41 pm
could not find any in SA so used resistors and its still working fine.
volkspares. used to have them, if you ask Ivan from volkspares to get the armature or resistors he will get them for you.
https://www.bbt4vw.com/en/catalogue/3-e ... 6v-4-ohm-/
Posted: Tue May 07, 2019 7:41 am
by Wentzel
Hi,
I built a circuit to act as a current limiter for my dad's 58 beetle and it has been working fine on 12v for a few years already. I found the circuit on-line at a classic car site and will see of I can find it again.
Found it have a look here:
http://www.vw-resource.com/wiper1.html
Posted: Tue May 07, 2019 9:06 am
by Haans
I converted. The car to 12v ,....got gatvol of all the "issues",....with mods to the stroke of the 12v wiper and all seems fine to me.
Ps it only works when you drive in the rain right ?
Posted: Tue May 07, 2019 9:13 am
by 73type2
Thanks all for the responses. There was a later 12V wiper motor in my 1963 Beetle when I got it, but I like the original look of the 6V wiper motor. I'll follow up on the suggestions above,
Posted: Tue May 07, 2019 4:11 pm
by 73type2
Wentzel wrote: Tue May 07, 2019 7:41 am
Hi,
I read through Rob and Dave's article and it looks like I'm going this route as well. Seems quite simple and the components are cheap and locally available. mantech.co.za has everything I need to make up the circuit.
Posted: Thu May 09, 2019 6:55 am
by Wentzel
It is a small circuit and can be hidden easily. Hope it will work for you for some time.
Posted: Thu May 09, 2019 9:23 am
by 73type2
Yes, when I saw the circuit I recognized it from first year electronics, so I felt quite silly that I never thought of it.
Posted: Thu May 09, 2019 4:37 pm
by fig
In my experience, a 6V electric motor can easily handle 12V, it just spins twice as fast.
I've been running my 1963 Dormobile's 6V wiper motor on 12V for more than 20 years and 270k km so far without any issues. I was warned the faster speed would wear out the linkages, but that hasn't happened.
To convert a 6V starter motor to 12V, just replace the solenoid with a 12V one and ensure the bendix has the correct number and pitch of teeth for your flywheel.
Posted: Fri May 10, 2019 10:56 am
by 73type2
Thanks Fig. Yes, I'm still running my 6V starter with 12V without problems.Installing that little current limiting circuit is cheap enough to be worth a try.
