Hi guys, what is the purpose of the port/tube on the twin carb headers of my type 2/4 motor?
Sent from my SM-G950F using Tapatalk
Ports on Type 2 twin carb headers?
- Has thanked: 191 times
Re: Ports on Type 2 twin carb headers?
if I'm not mistaken, those are connect from one manifold to the other with a decent sized hose. It helps the engine to drive and idel smoother by balancing the pressure pulses.
- mhsmuts
- What model do you have?: Variant type 4, 412
- Been thanked: 4 times
That makes perfect sense. It could balance the intake vacuum pressureTony Z wrote:if I'm not mistaken, those are connect from one manifold to the other with a decent sized hose. It helps the engine to drive and idel smoother by balancing the pressure pulses.
- Been thanked: 539 times
Perfectly correct, this stops the fuel from stop / starting in the manifold, giving a buffeting effect.
When the fuel flows then has to stop, and then start flowing again.
Makes balancing the carbs much easier as well .
Means your car runs smoother.
