Ghia fuel sender unit "rubber" seal sweating??
- Camshaft
- Been thanked: 107 times
Morning all, Noticed that this sender unit seal is not doing it's job properly?
What type of sealant can I use to add to the seal in question ?
Don,t overfill you say ?.,......I wish I could afford it !!
Speed humps and potholes requires some braking and acceleration,...and not much baffling inside the tank!!
Would a thin line of Sikaflex do it,......something that comes into contact with fuel,....that will keep the seal
Talk to me please
Talk to me please
Re: Ghia fuel sender unit "rubber" seal sweating??
Most sealers are not fuel grade, and will soffen up.
I would go to your BMG (Bearing Mann) an get a sheet of chemical grade packing, and cut a set of new gaskets.
- Camshaft
Thanks gents,...new gasket it will be,.......with a 'small' smidge of "red indian" perhaps or not!
Ps Herman,..this .."chemical" grade? Is like thickish paper type thing ?,....like we know from way back then?,.....or is it a rubber/ neoprene type thing?
Will go this week.
Will go this week.
both will work even well
- fourier
- Has thanked: 31 times
- Been thanked: 37 times
Or you could make a new seal out of thin cork. Works perfectly without any goop.
(o= i =o) (o\ ! /o)
- Has thanked: 191 times
my thoughts too, just use cork
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
Oh man...how times have changed.....back in the day, I used my cork for something completely different
- Camshaft
Some of us still use our 'corks',....less than before ! Butstill in use,.......
Me thinks!!
Will if I. An get thin cork,....2nd will be packing....chemical grade!!
Regards Haans
Me thinks!!
Regards Haans
- freddiebooysen
- Been thanked: 47 times
Haans.
You going off topic a bit there
Chemical Grade you referring to those Blue pills ?
- Camshaft
Any "chemical" assistance to enhance performance is acceptable nowadays!!
Anything to stop a leak!!!!
- What model do you have?: 1600 off-road thing
- Has thanked: 34 times
- Been thanked: 5 times
Haans, a leak now and then is fine. Its the sputtering and the occasional backfire that one needs to look out for
- Camshaft
Well.............have put a cork init !! Without ANY goop / lube or any other liquids!!
Have been for a trip to coffee and koekies in town,.....qtrly thing at the local speedshop,...
Smell is better,....have yet to fill up !,..saving up for this,...will let you know if the cork did the trick
- Camshaft
Hmm,....well. Cork did not last long !! All well to George butwhen I filled up on sunday morn, it was not long and we could not breath in the car!!
Cork gasket swelled up,.. and something is wrong. Chemical grade gasket it will be!,
Sorry only one picture of the trip,..my phone gave up on me !
use nitrile rubber
