1973 Beetle Jack
jacquesbotha
What model do you have?: 1973 Beetle 1600
Has thanked: 7 times
1973 Beetle Jack
Post by jacquesbotha »
Anybody have a '73 Beetle that can post or send me a picture of what the jack looks like? I know it fits on the floor underneath the rear seat on the RHS. Anybody have one for sale perhaps? Bought the car without any tools. Much appreciated. Jacques 0834544931
Been thanked: 100 times
Re: 1973 Beetle Jack
This is what I found using Google:
I can't see your pics, but I believe the 1970s beetles had a scissor jack with a square extension that engaged with the jacking point.
fig wrote: Thu Dec 12, 2019 1:03 pm I can't see your pics, but I believe the 1970s beetles had a scissor jack with a square extension that engaged with the jacking point.
The pics I posted do not show the jack you describe, but the text says that it is for '72 upward Beetles. I have a jack in my 1971 Beetle, which I believe was originally issued with the car, which fits what you describe. At first I thought it might have been a South Africa only item, but it's offered by Jbugs.com as well. Image below:
jacquesbotha
Thanks for all your input, now only to find a scissor jack like that, without having to import one.
Herbie
Been thanked: 35 times
Post by Herbie »
Jacquesbotha, did you manage to find one?
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
jacquesbotha
Herbie wrote: Fri Apr 24, 2020 6:54 am Jacquesbotha, did you manage to find one?
Sorry, only saw this now. No unfortunately not yet.
Why not use a normal scissor jack and weld a piece of square bar that fits in the Beetle slot?
jacquesbotha
Suppose I can try that as well.
John Alves
Been thanked: 48 times
Post by John Alves »
73type2 wrote: Tue May 12, 2020 9:49 pm Why not use a normal scissor jack and weld a piece of square bar that fits in the Beetle slot?
its a bit more complicated than that, the bottom is also offset, but doable
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
Just a straight jack with square tube welded on will not work as the car rotates away from the jack and the top of the jack rotates away from the car,
This could lead to an injury waiting to happen,
Rather use the normal scissor jack on the normal way.
omo
Riaan.N
Oil Seal
Been thanked: 38 times
Post by Riaan.N »
Volkspares should have these jacks.
