Morning all
Got a 1600 TP with a solex 34 pic carb.
Noticed that fuel was running out of the butterfly shaft ,both sides that was after traffic driving coming home from work.Monday.
Last night idled the bus got it warm and no leaks untill I switched off and fuel leaking again out the shaft.
The shaft bushes don't feel bad at all.
Checked the float seems fine.Please what to check next as I don't think its the bushes but flooding causing the leak as there is fuel in the engine oil.
Any advice to guide me to the source of the problem will be greatly appreciated.
Fuel leak
- Been thanked: 98 times
Re: Fuel leak
Needle & seat is toast, or the fload level is way out.
- Has thanked: 51 times
- Been thanked: 7 times
Re: Fuel leak
Thanks for the advice ,new needle and seat ,mechanical fuel pump? so if switched off would there still be to much pressure.I read about the fuel pump push rod and do have the shorter one out of the 2.
- Has thanked: 34 times
- Been thanked: 5 times
Re: Fuel leak
I would also check the fuel pressure. I am not sure whether the mechanical pumps keeps the pressure after switching off - maybe some of the more experienced members can comment on that - but in my mind: as it is a mechanical pump driven by the engine, I would wager that after switching off the engine, the pump would automatically keep the pressure (and if too high it will flood the engine even after switching it off).
- Been thanked: 541 times
Re: Fuel leak
As the pump has two one way valves, the pressure will stay if you do not have a leak.
Me thinks your old needle and seats can not hold the pressure of the pump.
You can adjust the pressure of the manual pump by shortening the shaft, or increasing it by welding a bit on, BUT only do this once you have a pressure gauge.
It must be able to read 3psi at max scale on the dial,to be accurate.
- Has thanked: 193 times
- Been thanked: 121 times
Re: Fuel leak
Stupid question if you made a thicker gasket to the pump brining the pump further out and the pump push rod will not get full travel.
Re: Fuel leak
Will work, also great idea.
