Crank pulley oil seal keeps popping out.
Come talk £%$ with us.
german
What model do you have?: none yet
Has thanked: 10 times
Flag: Germany
Post by german » Tue Mar 03, 2020 7:11 am
This is not air-cooled related don't know where to post it. Hope someone can give me advise please. I bought a Hyundai h100 2.6diesel bakkie and the t/cover oil seal keeps popping out. No sump compression but a little bit of end flow. I don't want to renew thrust washers as it runs perfectly. Is there some kind of loctite or any other suggestions please?
Terry Phillips
Has thanked: 182 times
Been thanked: 114 times
Flag: South Africa
Re: Crank pulley oil seal keeps popping out.
Post by Terry Phillips » Thu Mar 05, 2020 4:47 pm
Have you checked the breather is not blocked, I know you say no sump compression but take the breather off and check and clean it.
You can get a Loctite but silicone sealer is as good, I don't know about the end float so much it would have to be bad before it could effect the seal. Take the tappet cover off if the breather comes from there and have a good look at the breather. Make sure you use the right seal get one from the agent it might cost more but at least you know its right .I never use a sealer or Loctite putting seals in but that's just me.
german
Flag: Germany
Post by german » Thu Mar 05, 2020 7:22 pm
Thanks Terry. Yes I have checked the breather which is ok. I also tried a genuine seal and cannot see endfloat causing it but according to the agents it is a problem. I took a sharp centre punch and punched it like we used to with alternator bearings loose in the casings and will see what happens.
Thanks for your comment
Terry Phillips
Flag: South Africa
Post by Terry Phillips » Fri Mar 06, 2020 1:11 pm
Sell it buy a Toyota. :lol:
