Beetle dog box size
In Car Entertainment
Edmond
Has thanked: 22 times
Beetle dog box size
Post by Edmond »
Has anyone got the size of the bottom area of the dog box /rear luggage area in a beetle I want to draw up a shallow subwoofer box while I'm on lockdown since i cant work on the baja because it's at my moms house or does anyone have a drawing or spec for a shallow depth sub box
John Alves
Been thanked: 48 times
Re: Beetle dog box size
Post by John Alves »
920mm at rear
960mm ar front
390 between
remember that this measured at the bottom so the 390 will decrease as you move up as the rear seat is at an angle
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
Edmond
Post by Edmond »
John Alves wrote: Fri Mar 27, 2020 12:13 pm 920mm at rear
960mm ar front
390 between
Thanks John
Edmond
Post by Edmond »
960mm ar front
390 between
John can you pls measure the gap from the top of the back seat to the back of the dog box so I can work out the angle
John Alves
gap at top = 300mm
heigh of seat = 340mm
1968 1500 SP Beetle
Donovan D
Has thanked: 150 times
Been thanked: 73 times
Post by Donovan D »
Are you referring to this piece ?
I have one like this that came off the 59/60 beetle, if you want it its yours.
