Sub assemblies and Engines built
We will post some pics of Sub Assemblies and Complete Engines built by Vdubtech
Re: Sub assemblies and Engines built
When building a Aircooled motor 1 of the most important things is to determine what Compression ratio CR you want to build the engine to
Here are 2 sets of heads we Cc'd the heads that is part of working out the CR
I use a Pipette with paraffin
A round disc cut different sizes for
1600
1835
2L
2.4L Bore with a hole in the center to fill the head with liquid
Use grease on the edge of the disc to seal and there you go
There after you go to Pen and paper
I'll take some pics of actual formulas next
Hope this gives you guys a better idea
How to cc the Heads
Vdubtech will Also for a small exchange of Cash Cc your heads for you and help with the Calculation ImageImageImageImageImageImageImageImageImageImageImageImageImageImage
