Good day to all
What would the symptom of a weak oil pressure control valve be? I know what happens when the pressure relief valve sticks open, but am not familiar enough with the oiling system to know how a weak pressure control spring (the shorter of the two in a dual-relief case) impacts the oiling system.
Oil pressure control valve
Re: Oil pressure control valve
If the spring do not keep it tight to pressure
You will have lower oil pressure
- What model do you have?: JEEP (Veep)
Yes if it do not open you will have excessive oil pressure that could pop the oil cooler seals etc.
