Mixture screw removal Solex
Posted: Mon Dec 13, 2021 10:13 pm
by No More Landy
While trying to adjust the fuel mixture I found that I can fully close this screw without it stalling or affecting the idle. Some time back I had the carb reconditioned at Carb center so not sure what they did. Before this the screw definitely affected the idle and it cut the engine when screwed in. I was trying to remove the screw tonight but cannot get it out due to the o-ring keeping it in the pocket.
Any idea how to remove it other than glueing a screwdriver onto the head and also what could make it no longer adjust even though it does bottom out in the threads. Bit puzzled.
Sent from my SM-A107F using Tapatalk
Re: Mixture screw removal Solex
Posted: Tue Dec 14, 2021 9:14 am
All that comes to mind is that your butterfly is not closing fully
Posted: Tue Dec 14, 2021 9:46 am
by No More Landy
Thanks H, will check that also
Posted: Tue Dec 14, 2021 12:29 pm
by John Alves
retrovan wrote: Tue Dec 14, 2021 9:14 am
agreed, same thing happen to me
Posted: Tue Dec 14, 2021 12:34 pm
by John Alves
also float valve not shutting off fuel supply
Posted: Tue Dec 14, 2021 1:40 pm
by No More Landy
John Alves wrote:also float valve not shutting off fuel supply
I don't think that's it as there is no overflow into the throat during idle when I look down, nor when I shut her down.
How would the butterfly get stuck open?
Posted: Tue Dec 14, 2021 6:50 pm
Its normally wear on the shaft that moves the butterfly over and then it jams against the side
With a lot of use it can make a edge there and then uses it as a stop.
Try moving the shaft it may get back to its center position.
Posted: Tue Dec 14, 2021 9:06 pm
by No More Landy
I see the stopper screw is hard up against the choke cam when the car is warm and the thread is only just touching the cam.
But I will take off the airbox and have a squiz down to see if the flutterby is properly closed and is not catching on the body.
If not I will try glue my screwdriver into the slot and pull out the mixture screw so I can blow some air into that chamber ?
