Page 1 of 2
One for the gurus.
Posted: Mon Nov 12, 2007 8:17 pm
by Bennie Vorster
I have at last solved all my motor problems.
All I needed was to take out the VW Motor and installed a out of the box Rotex 582 motor
even if it did set me back R85 000.00
Posted: Mon Nov 12, 2007 8:20 pm
by Riftvalleyvw
You kidding right? If you cant keep your VW motor running that rotax will be a nightmare for you.
Posted: Mon Nov 12, 2007 8:55 pm
by vader
Why larry why? Take a pick of the rotax please I dont think I've seen one...
Posted: Mon Nov 12, 2007 11:10 pm
by Chris
Let me ask an uneducated question.A VW engine has a shroud in which a fan runs.The air that is generated from that runs over the engine to keep it cool.
If it doesn't have a fan shroud,but still has engine tin,doesn't the tin then keep cool air out,and warm air in?
Posted: Mon Nov 12, 2007 11:40 pm
by Riftvalleyvw
Huh???? I must have missed something.....
Posted: Tue Nov 13, 2007 7:05 am
by calooker
What are you doing with the VWAC motor, spares maybe, I could be interested, let me know.
Rui 082 830 6493
Posted: Tue Nov 13, 2007 2:50 pm
by fig
I see you followed my advice re the Rotax.
While ACVW engines are very simple and easy to maintain, an engine that was giving mysterious problems and possible warnings of imminent valve failure, as yours was, is not an engine that I would trust to power an aircraft.
If I had access to a scanner I could share with everyone an original VW Service Bulletin from 1955 warning against using VW engines in aircraft; it makes quite humorous reading.
Posted: Tue Nov 13, 2007 4:41 pm
by Chris
Chris wrote:Let me ask an uneducated question.A VW engine has a shroud in which a fan runs.The air that is generated from that runs over the engine to keep it cool.
I'm still asking!
Posted: Tue Nov 13, 2007 4:53 pm
pretty much, but I think its a trick question
Posted: Tue Nov 13, 2007 5:43 pm
by forcecooled
Yelo- My 12 cents worth!
The cooling on an aero engine or VW motor is done By the airflow which results from the plane moving thru the air, and by air blown thru the motor by the prop as well . Its not just a case of plonking a kaalgat engine under the cowling and expecting the airflow to cool it - it wont happen !
When the installation is designed and fabricated special attention has to be given to creating a plenum chamber above the motor and an area of low pressure under the engine to allow the hot air to escape freely from below the motor and out of the cowling. forget me not plates are often installed under the cylinders to ensure cooling to the bottom of the cylinders.
The hot air made by the motor is also harnessed to by the means of constructing muffs wrapped around the exhaust pipe ( like small VW heat exchangers) whick will feed hot air to the carb when needed , and the cabin for heating and defrosting. These muffs are fed with high pressure air from the plenum chamber and the flow is interrupted by flap valves that are operated by levers or knobs in the cabin.
Next time you are at a small airport, have a peep under the cowling of a piper 140 or so that has hinged engine covers and you will see how it is all done --- actually really simple!!
Chaars
Bill
Posted: Wed Nov 14, 2007 8:16 pm
by forcecooled
Hello?
Posted: Wed Nov 14, 2007 10:27 pm
hi
Posted: Wed Nov 14, 2007 10:52 pm
by forcecooled
hi !
Posted: Wed Nov 14, 2007 10:53 pm
by Bugger
hi! lo
Posted: Wed Nov 14, 2007 10:55 pm
by hitlers revenge
Hi dee hi
