13B conversion
Posted: Sat Dec 29, 2007 4:37 pm
by Surge
Since Bugger asked me so nicely to post some pics ...
Hope this is the right forum since it's not an aircooled project but the conversions forum is under "technical".
I started this project in 2003 but for the last 4 years it has been on hold due to finances.
Originally it was going to be a very unique, mid-mount V6 conversion with a special transfer gearbox mating the V6 to the beetle gearbox but due to safety concerns I shelved the idea. In 2006 I went to Cars in the Park at Swartkops race track to take a peek at the rotary conversions and after taking a look at some conversions I was sold.
I've recently dusted off the cobwebs and plan to finish enough of the conversion to get it road worthy before May but these things always take longer than expected and I'd rather take my time and do a proper job.
The bug before any mods.
1974 vintage with virtually no rust on the pan and some minor dents and bad paintwork to be fixed up.
Solid axle ... from a trailor. :D (Took gearbox out to rebuild it.)
Cutting the wheel well away for the big 3 core radiator. I did not enjoy this part since the body was in such good shape.
Frame to brace the front end.
One very clean 13BT series 4 engine from Japan. It's a complete engine (turbo, air pump, alternator, starter motor, aircon compressor, power steering pump, etc.). The only thing that may be an issue is that the alternator has obviously been replaced and I'm not sure whether I was given a dud one but that's a minor thing to get fixed. Official power output is 136kW and a bit over 250Nm of torque with all the accessories.
I was going to build a bumper/airdam but I'll leave that for a bit later (after I get the car on the road).
Rough cut with curved turn indicators.
Bumper section without airdam. The bottom of the airdam will end where the small bits of polystyrene underneath are resting.
Bumper and air dam joined with very basic shape. Slightly raised area for the number plate. Still have to add a lot more compound curves.
The final look of the bumper and airdam will be something along the lines of this with an air intake in the airdam for the radiator and aircon heat exchanger (yes I plan to add air con as well).
Re: 13B conversion
Posted: Sat Dec 29, 2007 5:41 pm
by ZeroAxe
Surge, pleas dont be offended, but personally I dont like that last bumper(pic). Reason for ;e saying that, is that if you go for a front like that, you *have to* add so;ething silly like that whale tail on the back. Otherwise the car doesnt look good at all from the side.
Ok, with that out of the way.... I think it is cool that you are going to make this whole thing out of scratch!! Please, I am curious, and am sure that others are too... So keep posting pics of the progress :hangloose:
Re: 13B conversion
Posted: Sat Dec 29, 2007 6:10 pm
by Surge
ZeroAxe wrote:Surge, pleas dont be offended, but personally I dont like that last bumper(pic). Reason for ;e saying that, is that if you go for a front like that, you *have to* add so;ething silly like that whale tail on the back. Otherwise the car doesnt look good at all from the side.
Yeah, it's not going to look quite like that and I'm not sure if I'll actually finish it. I may adapt on of those lip type airdams and keep the stock bumper instead.
Was aiming for something more like this :
Re: 13B conversion
Posted: Sun Dec 30, 2007 5:48 pm
by 4agedub
Should be a nice converson.
I like bumper on that blue beetle. Looks nice and neat. If I remember correctly you can purchase those bumpers over the net, but they retail for a lot of $$$
Good luck with your convertion
Re: 13B conversion
Posted: Sun Dec 30, 2007 7:20 pm
by ZeroAxe
Yeah Surge, now you are talking!!!! That Blue one is better!
Re: 13B conversion
Posted: Sun Dec 30, 2007 7:50 pm
by Surge
The blue one is from J-Sports in Japan.
I got a quote from them in January 2004.
Bumper/airdam = $527.27
Shipping to USA = $375.93
Total = $903.20 = ~R6200
Re: 13B conversion
Posted: Sun Dec 30, 2007 10:08 pm
by ZeroAxe
R6200!!!! :shock:
:finger4u:
I am sure that can be MADE for MUCH cheaper!!!!
Re: 13B conversion
Posted: Fri Jan 11, 2008 4:26 pm
by 4agedub
Any updates ???
Re: 13B conversion
Posted: Fri Jan 11, 2008 5:02 pm
by Surge
4agedub wrote:Any updates ???
I have to wait till the end of the month to get the adapter set up from Bugger - cash reserves a bit tight this month since I had to lay down a deposit for a place to rent in Centurion. :(
I don't want to start stripping all the extras off the engine until I've visited Bugger and seen what he's done on his conversions.
