Page 1 of 2
1796cc Engine Build (Pics added)
Posted: Tue Jan 08, 2008 2:51 pm
by calooker
I have started the assembly of Nic (aka) Merlin's little monster, 86,5 bore, 76,4 stroke.
Plenty pics to come, watch this space.
List of parts collected
Alighned bored and refaced AS 41 block clearanced, done by me.
Metal Leve main bearings 0,06" OD & standard ID
86.5 Mahle pistons & rings, stock OEM sleeves 0,04" oversize
CB Perfomance 76,4 CW crank, 8 doweled with lightened matching flywheel
Camtech C35 reground cam, 276 deg 9.5mm lift @ cam
Refaced and parkarised OEM cam followers
35x32 heads ported by me with 49cc chambers for a 8:1 CR
Stock rods clearanced, done by me.
Some work done pics to follow.
Re: 1796cc Engine Build
Posted: Tue Jan 08, 2008 2:55 pm
by Merlin
I've no idea what all of that is, but damn, it sounds sexy. ;)
Porting the Kadron manifolds too? :p
Posted: Tue Jan 08, 2008 2:58 pm
by Blitzkrieg
Noice :o
What would the power be like compared to a mildly modified 1700 Type 4 engine :?:
Posted: Tue Jan 08, 2008 3:12 pm
by calooker
CC fot CC a T1 will be more exiting than a T4, I now others may have their views on this one but the T1 will put a bigger smile on your face.
T4 head design can't flow as well as T1 head, simple as that.
Posted: Tue Jan 08, 2008 3:21 pm
Sounds like a bundle of fun engine with good reliability worked into it.
Odd size I must admit, would love to see how it runs.
Posted: Tue Jan 08, 2008 3:25 pm
by calooker
If you go onto the CB site they built a milage motor with a simillar setup, check it out.
http://www.cbperformance.com/articles.asp
Posted: Tue Jan 08, 2008 4:40 pm
by 4agedub
This should be an interesting engine.
My first 1776 redlined at 8000rpm with stock rods and a scat c65 cam. Was fun to drive and everyone thought it was a rotary with the noise at high rpm.
Posted: Tue Jan 08, 2008 4:44 pm
by Blitzkrieg
4agedub wrote:This should be an interesting engine.
Crazy rpm :shock: :shock:
Would love to modify a 1700/1800 Type 4 engine to spin so high :twisted:
Posted: Tue Jan 08, 2008 7:27 pm
by ZeroAxe
BB, perfect balance, good quality parts and carefull tuning is all you need.... :wink:
Posted: Wed Jan 09, 2008 3:14 pm
by 4agedub
Something like that. I ran a counterweighted 69mm crank with a 3kg flywheel, all balanced off course. Twin 40mm idf carbs. Ran like an absolute dream and made 70kw on the wheels in JHB.
Posted: Thu Jan 10, 2008 11:09 pm
by 2BugMe
What the heck does "parkarised OEM cam followers" mean????? :shock:
Sounds like a beautiful setup...Good luck dude!!
Posted: Fri Jan 11, 2008 7:29 am
by calooker
parkarised = surface hardening
OEM = original German part
Posted: Fri Jan 11, 2008 8:37 am
by 2BugMe
Hey cal,
How do I go about doing that? and who would be able to do it?
And what implications would this have on the push rods? Would you need to upgrade to Chro-Mo push rods or will the originals suffice??
Happy building!! :mrgreen:
Posted: Fri Jan 11, 2008 8:43 am
for an original engine, origianl parts will work fine.
I suspect you need to go to this section of the site and do some reading...
http://www.aircooledvwsa.co.za/viewforum.php?f=8
look at things like....
http://www.aircooledvwsa.co.za/viewtopic.php?f=8&t=58
http://www.aircooledvwsa.co.za/viewtopic.php?f=8&t=55
you should be able to learn a lot
Posted: Fri Jan 11, 2008 9:00 am
by calooker
Hey 4agedub, 3 kg flywheel, how did you get it that light was it a aly. item? Shit that is light, must have gone from 1000 to 8000rpm in the blink of an eye.
I had a FW done that looked like swiss cheese and it was 4.7 kg's not much more could be done, I think.
http://memimage.cardomain.net/member_im ... 5_full.jpg
