Page 1 of 2
A - Frame
Posted: Mon Feb 18, 2008 9:56 am
by Wentzel
Hi,
I want to biuld myself a proper a -frame for my beetle and was wondering if someone can help out with dimensions, specs or pics. I was thinking of using exhaust pipe and bend it where needed adding the needed brackets and cross supports etc, or will it be to weak for this purpose.
P.S. I hate towing it but the fuel $$ is a problem . . .
Thanks in advance.
Re: A - Frame
Posted: Mon Feb 18, 2008 10:01 am
by Blitzkrieg
Hehehehe a few Sundays ago I had one very scary experience with an A-frame, but if you make one up using proper steel etc, it should last a long while
We towed my white fasty from Orkney to Pretoria (thanks Pine!!) using an A-frame with no hassles whatsoever
Re: A - Frame
Posted: Mon Feb 18, 2008 11:55 am
by 4agedub
Rather spend the time and build yourself a trailer.
Re: A - Frame
Posted: Mon Feb 18, 2008 12:39 pm
by Wentzel
Hi,
Yes a trailer can work better but big $$ and I heard that it is difficult te register home made trailers these days. I will think about it, maybe an better option. Any Plans, pics of trailers??
Re: A - Frame
Posted: Thu Feb 28, 2008 4:42 am
by Riftvalleyvw
If what you want is the towing atachment for a beetle that hooks up at the front beam, I have plans. What format do you want them in? What type of hitch is on the car? Ball? of pintle?
Re: A - Frame
Posted: Thu Feb 28, 2008 5:58 pm
by Aircooledwannabee
Trailers especially home made are a drag to get through roadworthy and it's another license to be taken out on yearly basis. Nice strong A-frame, yup thats how I'd go.
Re: A - Frame
Posted: Fri Feb 29, 2008 1:59 am
by Riftvalleyvw
This is the one that I make. It is made from 1-1/2" or 40mm water pipe. works good.
Re: A - Frame
Posted: Fri Feb 29, 2008 11:05 am
by Wentzel
Hi,
Thanks unfortunately I'm unable to see the pics but any plans or advice will be welcome. Wat format you got?
Thank you
Regards
Re: A - Frame
Posted: Sun Mar 02, 2008 12:56 am
by Riftvalleyvw
Ok Ill break it down into drawings that will fit and post it here and e-mail it to you.
Re: A - Frame
Posted: Mon Mar 03, 2008 7:53 pm
by CHARLIE COOPER
i once towed a bug from cape town to jhb no problems
just make it strong
Re: A - Frame
Posted: Mon Mar 10, 2008 7:06 pm
by Riftvalleyvw
Re: A - Frame
Posted: Fri Feb 03, 2012 6:14 pm
by Rassie
Thanks for the plans, I emailed them to a friend of mine in JHB, received the frame today!
Re: A - Frame
Posted: Fri Feb 03, 2012 10:15 pm
Your friend put in the right cross braces, you should be save with it.
Here is the thread of the A-Frame I made, but upgraded it to be able to tow beetle or bus.
http://www.aircooledvwsa.co.za/viewtopi ... =4&t=22298
Will be putting the drawing up on the above thread for others soon.
Or if others want one, will get my welding guy to make up some....
Re: A - Frame
Posted: Fri Feb 03, 2012 11:21 pm
by Rassie
Incidently the frame was made up also by Herman, but Herman in Kempton
So if there are JHB based members here in need of this I am sure he will be able to assist, he does this kind of manufacturing. I have no clue as to what it would cost.
Re: A - Frame
Posted: Mon Feb 06, 2012 2:12 pm
by Bratjie
Hi Wentzel, I have both basic frames, one for the beam attachment and the other for the front bumper bracket attachment, you're more than welcome to borrow and copy, one 1 condition though - he-he, You have to come with your turbo bug lol. Just joking but you're still welcome.
