ENGINE CC?
Posted: Mon Mar 17, 2008 6:45 am
by SUZIE
85,5mm sleeve diameter is 1600cc i beleve
83.5mm sleeve diameter is 1500cc i beleve
are these above ones right?
what is the sleeve diameters for?
1100cc
1200cc
1300cc
Re: ENGINE CC?
Posted: Mon Mar 17, 2008 7:15 am
by Dawie
1131cc - Bore 75mm, stroke 64mm (early fifties "25hp")
1192cc - Bore 77mm, stroke 64mm (late fifties with gen pedestal part of case,often mistakenly called "1100")
1192cc- Bore 77mm, stroke 64mm (early sixties with separate gen pedestal)
1285cc- Bore 77mm, stroke 69mm
1493cc- Bore 83mm, stroke 69mm
1584cc- Bore 85.5mm, stroke 69mm
1679cc- Bore 90mm, stroke 66mm (type 4)
1795cc- Bore 93mm, stroke 66mm (type 4)
1971cc- Bore 94mm, stroke 71mm (type 4)
Oversize pistons are 0.5mm and 1mm more than standard size.
Re: ENGINE CC?
Posted: Mon Mar 17, 2008 7:24 am
by Dawie
Original beetle was 986cc, 70mm bore and 64mm stroke.
Re: ENGINE CC?
Posted: Mon Mar 17, 2008 7:35 am
by SUZIE
Thanks Dawie
This will help me alot.
Re: ENGINE CC?
Posted: Wed Mar 19, 2008 11:59 am
by IMPI
There is also 87mm oversize on 1600s giving 1641cc ie 1.5mm oversize and if you are adventurous there is toyota pistons at 88mm which gives 1679
etc etc etc
Re: ENGINE CC?
Posted: Wed Mar 19, 2008 12:40 pm
by lowlight
77mm bore pods for the fixed genie pedistal and the loose ones, are they inter changeble?
Re: ENGINE CC?
Posted: Wed Mar 19, 2008 1:48 pm
by IMPI
Nope the 36 hose had smaller spigots in the head I suppose some types of cylinder can be modified.
Armand.
Re: ENGINE CC?
Posted: Mon Apr 07, 2008 8:04 am
by karmakoma
interesting
Re: ENGINE CC?
Posted: Mon Apr 07, 2008 9:45 am
by Blitzkrieg
IMPI wrote:There is also 87mm oversize on 1600s giving 1641cc ie 1.5mm oversize and if you are adventurous there is toyota pistons at 88mm which gives 1679
etc etc etc
That Toyota piston modification sounds rather interesting. Any idea of how much power one can make out of a 1679 engine
Re: ENGINE CC?
Posted: Mon Apr 07, 2008 7:35 pm
Blitzkrieg_Beetle wrote:IMPI wrote:There is also 87mm oversize on 1600s giving 1641cc ie 1.5mm oversize and if you are adventurous there is toyota pistons at 88mm which gives 1679
etc etc etc
dont even think about it. Toyota piston is heavier than stock (by a lot) and the cylinder is honed out so far it cant maintain its shape properly... if you want to do that, get the "machine in" 88mm kit that come with pistons and has a properly thick cylinder wall. But for the same price you can build a 1776 with thick walled sleeves
Re: ENGINE CC?
Posted: Tue Apr 08, 2008 9:28 am
by Blitzkrieg
Thanks for the input Tony Z.Thought that it would make a nice budget combo, as those Toyota pistons can be had for free
Re: ENGINE CC?
Posted: Tue Apr 08, 2008 9:53 pm
3 options.
1) cheap
2) quality
3) performance
choose any 2, you cant have 3
Re: ENGINE CC?
Posted: Wed Apr 09, 2008 8:52 am
by Blitzkrieg
I've heard that one before and it's most definitely true
