BRAKES
Posted: Tue Mar 25, 2008 11:09 am
by virek
Ever since I got the car back from the mech, the brakes have been binding terribly. Especially when driving around for a while. I read quiet a bit on the subject
some okes had some bad experiences.
Anyway the car is at Robbie ( Beetle man in PMB )
He is doing all 4 linings - 1 wheel bearing - 2 seized hoses for R1100. Price sounds fair to me.
Is there anything else I need to look out for? Hope she comes right, the binding is the most annoying thing.
Lots of moola this bug is costing me
Regards
Re: BRAKES
Posted: Tue Mar 25, 2008 11:52 am
by fig
Binding brakes are often caused by aged flexible brake hoses, which start to behave like a one-way valve. This can also be caused by insufficient play between the brake pedal pushrod and the master cylinder.
If you need to replace one of the flex hoses, I would replace all of them. Likewise, I never replace wheel bearings except as axle sets -- if one side needs replacing now, the other will likely soon follow.
Re: BRAKES
Posted: Tue Mar 25, 2008 1:12 pm
by virek
Thank you
Re: BRAKES
Posted: Tue Mar 25, 2008 3:27 pm
by Blitzkrieg
Best thing to upgrade to is disk brakes all round
Re: BRAKES
Posted: Tue Mar 25, 2008 3:50 pm
by fig
Unless you're building a high-performance Beetle or live on a mountain pass, the stock brakes, when correctly set up, are quite adequate.
Re: BRAKES
Posted: Wed Mar 26, 2008 8:58 am
by virek
The brakes are actually quiet good. This was before I sent it for a service. Should be even better now.
Getting the car back today - cant wait. Hope that binding issue is sorted.
I am trying to keep her as standard as possible. One mod leads to another and is a costly affair. Before my bug I had a twincam turbo. Learnt a good few lessons
Re: BRAKES
Posted: Fri Mar 28, 2008 10:54 pm
by badbug
Beetle man is a ripoff. I'm in Pmb myself. Give me a call sometime. 0845827429.
Re: BRAKES
Posted: Tue Apr 08, 2008 3:40 pm
by SUPER DAN
I have exactly the same problem of binding brakes on my 68 beetle which started after it came back from a service. I am in Centurion and need to get hold of someone who will be able to give advice of how to fix or where I can go to to get the problem straightened out. The binding is most annoying and very frustrating.
