Electric Windshield Washer
Dirk
Post by Dirk »
After looking around I've concluded that it's safer to convert the "spare-wheel-pressure" system with an electric one.
Does anyone have any suggestions/notes/comments regarding this?
BUGGOFF
Re: Electric Windshield Washer
Post by BUGGOFF »
i used a jetta bottle for this. got it at a scrap yard for R35. u just need to put a switch, horn button located at midas, somewhere. works perfectly.
You can also keep the original water bottle, and just add an electric pump in-line of the water pipe, and a switch on the dash.
Dirk
Post by Dirk »
Now that's what I was hoping for.
Any advice on retrofitting the existing push switch to work the pump?
lowlight
Post by lowlight »
Take all those pipe thinies off(ques work here) and try to fit those micro swiches at the back that you can push with the button? Thid is a long shot.
Guess it will be possible but in the process you will break a few switches...
Search on TheSamba to see if it has been done before?
