Split bus box
Posted: Tue May 20, 2008 12:33 pm
by Bad Ass Bob
how easy to turn the crown wheel and pinion to change over to straight axel but using the origional gear box
????????????????????????????????????????????B.A.B
Re: Split bus box
Posted: Tue May 20, 2008 6:30 pm
by Bugger
It is fairly easy that part just before you strip the side covers off feel with your hand how the backlach between the diff and the pinnion feels to get an Idea what it should be or feel like
It should have a slight play very little so when you strip off the side covers swop them olso with the diff around to the other side so thr back lash should stay thr same so before you use any sealer or so first trail fit all and feel the back lash it should stay the same if not if it is to tight you need to check the shim at the crownwheel side and needs to go thinner
You could give me a call aswell
Pierre 082 600 8663
Re: Split bus box
Posted: Mon May 26, 2008 2:55 pm
by Bad Ass Bob
Thanks for the advice, thats for future reference, !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!B.A.B
