drum drilling
Posted: Tue Mar 14, 2006 1:23 pm
by Bugboy
I have a set of 5 x 100pcd rims that came off an old Kombi, sort of looks similar to the Empi Rims. Do you guys know if they have adaptors for these? Was also considering drilling my drums to o,is that advisable?
Can you help
Bugboy
Posted: Tue Mar 14, 2006 2:27 pm
by calooker
Kombi PCD is not 5x100, that is like Golf 3, Kombi PCD it is more like 5x112 (can't remember exact), you can get adapters from Volkspares for those wheels, if you are using the std wide 5 beetle drums to re-drill then forget it, it will not work as they don't have a surface that will allow the new wheels to sit flush unless you get some sort of fancy spacer made up, so you are better off just getting the adapter plates.
