Pedal cluster
Posted: Thu May 29, 2008 8:59 am
by Lieb
Hi guys
I had to repace a broken cluch cable on my Beetle. Everything went well,although it took some time to hook it up I was very careful when I put everything back but now the brake and cluch pedals can move about 25mm from side to side.What did I do wrong.
Lieb
Re: Pedal cluster
Posted: Thu May 29, 2008 9:54 am
by Bugger
Did you refit the c cips holding them together
Re: Pedal cluster
Posted: Thu May 29, 2008 10:35 am
by Lieb
I put the c-clip that holds the accelerator shaft in place back and the one holding the shaft going to the brake mastercylinder are there others?
Re: Pedal cluster
Posted: Thu May 29, 2008 11:17 am
by calooker
There should also be a large Dia. return spring on the assembly which is a bitch to secure and load when refitting the assembly, is that there?
Re: Pedal cluster
Posted: Thu May 29, 2008 11:31 am
by Bugger
On the left side of the tunnel there should be a guide bracket aswell to the right of the tunnel with a plastic u shape plastic and then the bracket holding it down at thr right of thr assy then it should not move around
Re: Pedal cluster
Posted: Thu May 29, 2008 11:50 am
by Lieb
I'll crawl under the dash again tonight to see what goes.
Lieb
