Door pad/card/panel removal
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Hey guys, i have searched and given up. So yeah. How do i remove my door pads, (the vinyl covered boards on the doors, i've gotten the handle and window winder off so far....
Re: Door pad/card/panel removal
Remove the handle,window winder,like you did,And then behind the little plate on the door lock mechanism there is another screw.Then take a flat object,and slowly and carefully wedge the panel away from the door.The panel should have triangular clips that pushes into holes in the door.
If I recall correctly,there are 18 clips on the panel.
- bugspray
- Floorpan
If you pull the trigger back,there should be a plate that covers the screw,remove the little plate.
- bugspray
- Floorpan
