Donovan D wrote:
Tue May 19, 2020 9:19 am
Bit of progress on the old girl. Decided to give it a go at the interior. So far so good, might not be 100% but seems ok.
Firstly got some felt from the place in Maitland. The felt is horrible, its very flaky/breaky if I can call it that.
Also bought some adhesive spray from the local hardware store. This had a nice nozzle that didnt make to much of an overspray mess and was quite easy to control where the glue went. But the glue was no good.
The material is a sort of hesian material. I was hoping for something with a bit more stretch and more heavy duty. If you spray too much glue on it goes straight through the material and leaves a mark. I did the rear window and a day later I was not happy with the end result. I pulled of everything, cleaned up the felt off the body and started again.
Luckily I had a big enough piece of extra felt that I forgot about. This felt is a lot more solid and does not fluff apart. Also bought the alcolin spray. The nozzle is like a normal spray can, it goes everywhere. But it sticks ! Redid the rear section and its loads better. Started with the roof but could only go halfway as Im waiting for the vinyl.
Ek dink daar is n Paar pakkies Files wat nie meer GeCLIP is nie :drunks: :drunks: :drunks: :drunks: :drunks:
Donovan D
Has thanked: 129 times
Been thanked: 61 times
Post by Donovan D »
Did the door cards. I was running out of staples and this is the result. The line with less staples is clearly more wavy than the top panel
Still need to fit the armrests and the trim. Carpets are 95% trimmed and almost ready to get the edging done.
Im after 2 of the coat hooks, if anyone has please let me know.
acpaterson
Has thanked: 80 times
Been thanked: 128 times
Post by acpaterson »
Howzit Donovan,
Coming on nicely bud. Are you leaving the carpets like that? Or do you intend to still edge them off? Will help to keep them neat and clean edged.
Cheers
Alan
Donovan D
Post by Donovan D »
acpaterson wrote:
Mon Jun 29, 2020 8:30 am
Howzit Donovan,
Cheers
Alan
Yes, getting them edged. Hopefully take it this week to be done.
acpaterson
Ahh, awesome.
fourier
Has thanked: 31 times
Been thanked: 37 times
Post by fourier »
Looks great!
(o= i =o) (o\ ! /o)
Been thanked: 51 times
Post by Haans »
Looking great !
The hook,.....if you cannot get,......have you thought of making it yourselves ? I made one for ghia's back seat strap,.....and was quite chuffed with the end result.........just a thought
