2.0 Golf engine and box-Sold
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
Hi all, I have a 2.0l fuel injected Golf engine in my Bay window. Running like a Swiss watch. Of course I'm converting back to aircooled, so make me an offer for full turnkey solution, including gearbox and management system. By turnkey, I mean, once you installed it in your car, you can turn the key and go
- Has thanked: 193 times
- Been thanked: 121 times
Re: 2.0 Golf engine and box
will that work in a T3 just after the engine and adaptor plate if it bolts straight in T3.Can you give me a idea of the price as it is now with gearbox then I can split it and sell the box later.
Last edited by Terry Phillips on Wed Oct 02, 2019 1:46 pm, edited 1 time in total.
- Eugene
Yes it will but in T3 you would need to raise the engine compartment to accommodate as is. Alternative would be to get the adapter plate that allows a slanted motor but you would also need special sump
Eugene can you pm me some sort of a price please you must have an idea of what you are after I don't want to throw numbers arround please. Thank you
- Eugene
Guys, I am thinking around 30K for complete solution. You install it yourself though. I will ask Pierre what he thinks a good price is.
This will be:
Complete engine and gearbox
Engine hanger and mounting
radiator cluster with fans
water bottle...hell, Ill even through in the heat gauge
5l of spring water
This will be:
5l of spring water
I think we I sugested a Price of R25-30KEugene wrote: Wed Oct 02, 2019 3:53 pm Guys, I am thinking around 30K for complete solution. You install it yourself though. I will ask Pierre what he thinks a good price is.
This will be:
5l of spring water![]()
Motor ---------------------------------R9900
EFI-------------------------------------R6500
Exhaust-------------------------------R2850
Adapter kit with Clutch -----------R6000
Cross members ---------------------R1950
EFI Fuel Pumps----------------------R1000
- Eugene
Thanks Pierre...combination now semi sold....deposit receivedBugger wrote: Mon Oct 14, 2019 10:59 am I think we I sugested a Price of R25-30K
- Eugene
Now, throw the years I should have learned that you don't through things in
Forgot to Mention the Belly mount Radiator
Steel Water Pipes and Rubber Hoses etc
