1800 luk clutch kit only R900
Get your parts here
Re: golf adaptor plate/flywheel /clutch [all brand new]
Golfmad wrote:Yes, read it, but I still dont understand so lekker.... I am mechanically handicapped to say it mildly
Then the only thing is :zhelp: ....... :roll:
kts customs
What model do you have?: 1971
Facebook: yes
Post by kts customs »
i used on of gilos kits and it worked well in bus bus
doing it again soon
I read 1800 Clutch kit
This means then it should be a 215mm clutch and a std beetle starter will work with this kit
I bought a kitt for Microbus and it has a 228mm clutch (if you want to use one of these 228mm kits then you need a spacer and a Bus starter in a BEETLE AND 1600 3 Rib Bus Box)
If the clutch is 215mm you will not need to modify Beetle or 3 Rib bus box to fit this specific kit
RICKY-R69
Post by RICKY-R69 »
Complete set-up from GILO is priced at R2216.00. With crossmember and engine mounts,just over R3000. A bit overpriced I would say!
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
RICKY-R69 wrote:Complete set-up from GILO is priced at R2216.00. With crossmember and engine mounts,just over R3000. A bit overpriced I would say!
I think this one includes the clutch kit as well.
buggyfan
Long Block
Post by buggyfan »
Bugger wrote:I read 1800 Clutch kit
Bugger ,you are correct it is a 215mm clutch
buggyfan
Long Block
Post by buggyfan »
this includes a brand new 215mm luk clutch kit aswell ,Gilo's price is on the adaptor and flywheel only .
ps this comes wth a guarantee that no Glue was used to stick parts together aswell!!!!!!!!!!!!!!!!!! :lol: :lol: :lol:
I see what you did there :lol: :lol: :lol:
228mm flywheel & 215mm clutch kit, I could be wrong but you have a problem?
buggyfan
Long Block
Post by buggyfan »
calooker wrote:228mm flywheel & 215mm clutch kit, I could be wrong but you have a problem?
thats the kit that GILO SUPPLIED and the clutch that they recommended ,but its not mine im just posting this on behalf of a buddy
Re: golf adaptor plate/flywheel /clutch [all brand new]pics
Gilo make the kit with both 228 & 215 FW, I would get your buddy to check if he has a matched clutch kit.
Has thanked: 36 times
Been thanked: 50 times
Post by flatfourfan »
Interested in the flywheel and adapter............will pay 2K for both. Sent him a sms and tried to call, but no reply. Spoke to Gilo Eng yesterday and the kit is R2600 excluding clutch, mounts and crossmember.
If you speak to him, let him know that someone is keen on it and will pay cash, no quibble.
- G
buggyfan
Long Block
Post by buggyfan »
passing on the message as im typing this
cheers, have been in contact with him.............
