This means then it should be a 215mm clutch and a std beetle starter will work with this kit
I bought a kitt for Microbus and it has a 228mm clutch (if you want to use one of these 228mm kits then you need a spacer and a Bus starter in a BEETLE AND 1600 3 Rib Bus Box)
If the clutch is 215mm you will not need to modify Beetle or 3 Rib bus box to fit this specific kit
RICKY-R69 wrote:Complete set-up from GILO is priced at R2216.00. With crossmember and engine mounts,just over R3000. A bit overpriced I would say!
this includes a brand new 215mm luk clutch kit aswell ,Gilo's price is on the adaptor and flywheel only .
ps this comes wth a guarantee that no Glue was used to stick parts together aswell!!!!!!!!!!!!!!!!!!
this includes a brand new 215mm luk clutch kit aswell ,Gilo's price is on the adaptor and flywheel only . ps this comes wth a guarantee that no Glue was used to stick parts together aswell!!!!!!!!!!!!!!!!!!
Interested in the flywheel and adapter............will pay 2K for both. Sent him a sms and tried to call, but no reply. Spoke to Gilo Eng yesterday and the kit is R2600 excluding clutch, mounts and crossmember.
If you speak to him, let him know that someone is keen on it and will pay cash, no quibble.
