Beetlefanatic`s Cabrio
Re: Beetlefanatic`s Cabrio By Bugger
Looking good.
The material gives you better traction when having a girl in the most uncomfortable position known to man....
In the back of a Beetle :-)
Now to get rid of those FUGLY white smiths wheels...
Don't worry my friend, the wheels are already sorted :wink:
Just to give you an idea of the wheel choice. (I think I posted this before).
Mags
Checking what it will look like
Has thanked: 19 times
I forgot we took those pics of the calipers holding the wheels :D
Secret weapon ? I was reverring to the plastic mesh that is fitted over the material to give it that cool breeze look
Going to look very nice with those BBS like wheels.
Are you going to lower it a little as well ?
Those are A-line Falcons. The BBS rims are going on the Bay.
Yes we are lowering it. That was just fooling around after I bought the wheels. The front beam with the adjusters is awaiting assembly and installation. The rear will be turned 1 spline I think. We'll see when we get there.
I can't wait!!
I should be assembling the Gearbox in the comming week or so :
Super 4 spider Diff
HD Side cover
3.88 R&Pinnion
std 3de
slight longer 4th ratio than std for driving on the highways after 2010 when construction is finished :D
special imported 2nd and 3de gear Syncros
and a Few BUGGERD Items to finish the Package off
Side shaft covers are yellow coloured electroplated and the disc brake hubs are Silwer coloured electroplated
More pics to follow
Finished the Transmission now and fitted the axle covers need to get some Bolts for the calipers and some ods and sods
and the Tranny will be complete
Then It is the Front Suspensions turn to get Assembled
Fetchig the Cabrio from the Upholster most probably on Tuesday to do all the swops :D and fit the Wheels :drunks:
Looking absolutely amazing!
But where are the pics???? :cry: :zhelp:
beetlefanatic wrote:But where are the pics???? :cry: :zhelp:
Where are the ones I mmsd you
Will take some later today after the calipers and everything is on
No MMS where I am in Boratland. :cry:
Please email some. Pretty pleaseeeeeeeeeeeeeeeeeeee! :mrgreen:
JohnHoffe
Post by JohnHoffe »
I'll phone the B and give him your request!
Thanks John! :hangloose:
The box with out the nose cone not sure what mounting type is on the cabrio
SOme box pics
Side view of the HD alluminium side cover to keep the super diff in side :D
Need to make up special brake pipes to connect to the Braided hoses to the calipers the calipers has a bigger size fitting as usual ans the std pipes is also to short Tony Z PM me :D
So what you think Bernard
Looking great Pierre. :hangloose: :drunks:
Do you have any pics of the discs and calipers? I'm dying to see what they look like up close.
