Beetlefanatic`s Cabrio
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Re: Beetlefanatic`s Cabrio By Bugger
Oh and an iPod would be wickid. But no radio functionality.... I think. And if yov do that, your going to need a pre amp or equalizer. The amp alone wouldnt b able to tune the right frequencies. Instead of 6*9z. Go with co axials in the rear under the seat, of if the front seats are done yet, put the speakers in the back rest. Herzt, JL audio, rockford, xtc audio are schweet. Check out metro audio or something like that. In the speed and sound mag.
rockford fosgate
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
I love Rockford, but the prices! I think there's only one place importing them and accredited to install them.1972 wrote:rockford fosgate![]()
Buy Lightning Audio,it's a subsiduary of RF.It's basically RF in a different package.It's what I use and half the price,same quality.
- bugspray
- Floorpan
Yup lightning kicks ass! RF in sheeps clothing. Go read up the ice thread, theres something about a droptop, and sound insulation, you may need that.
- Has thanked: 19 times
- Been thanked: 58 times
This was a
load of work to get this front end sorted with all the Urethane bits
You will see I maneged to get urethane cups even for the Tierods so had to strip the std cups off
Then the urethane cups would not fit properly then the Thick antiroll barr, had to modify the urethane mounts there
also aswell
But it is looking good
Just need a few small items to finish the front end off ready for fitting
also aswell
- 1972
wow that looks great ,nice work
wow
ZeroAxe
- Drive Train
I am sure you can go about it this way, but do you REALY want unbalanced discs??? With your Baja rusting aprt already, do you want it to SHAKE apart as well????vader wrote:Well you take a set of disks choose a drill bit, take it over to the drill press, center punch your pattern onto them, drill away and hay presto you have crossdrilled disks...
VW Enthusiast
- Matt
- Oil Cooler
- What model do you have?: '78 1600
for quality and affordabillity....6 inch starsound splits-front and back
4ch audiobank amp(ive had my amp for like 3 years and i hammer it, and its proved itself)
personally, i would say thats the best quality for rand spent. dont waste your time with 6x9's, they might save space and easy to install....
...but u'll neva get the sound quallity that you would from a split system. and the 6 inch is enough bass. if u go starsound with the amp, even better.
compatible components always work better. and u'll have a kickass install if it all one brand.
im sure plenty ppl will disagree.... just my opinion
- Matt
- Oil Cooler
by the way...is that anti roll bar standard? i see u talking bout the "thick anti roll bar"
looks very awesome....i feel a bit of jealousy coming over me.
congrats
congrats
hmmmm.... they have good mid-bass if in a decent tight small enclosure, but most 6" drivers cant even produce the frequencies that is usually referred to as bass. They fade out around the 120Hz region.Matt wrote:and the 6 inch is enough bass.
Food for thought.
- Has thanked: 235 times
- Been thanked: 234 times
- 6 inch starsound splits-front and back - R 7K, more or less
- 4ch audiobank amp - R 4K, more or less
- driving down Margate beachfront blasting Loslappie on repeat at deafening decibels - PRICELESS!!!
Matt wrote:by the way...is that anti roll bar standard? i see u talking bout the "thick anti roll bar"
congrats
It is a after market thicker one much stiffer than std
- 1972
bugger have you got more pics of the front beam???
