splitfan
Has thanked: 46 times
Been thanked: 26 times
Re: Split Scream !
Post by splitfan »
I could not have seen them @ autostyle (ive never been there) but anyhow doesnt matter now do you know if autostyle still has some i would like to get a spare set or two, John i used vibraseal i mannaged to get 3 rolls from a friend that just build a Cobra wanted to do the roof as well but decided against it just because of the weight of this stuff !!!thinking of rather using the high density foam that they use for soundproofing i wanna see if i can get the bus cooler a bit worried about the black roof :?
JohnHoffe
Re: Split Scream !
Post by JohnHoffe »
If you add something reflective to the inside of the roof, won't it increase the temperature on the outside of the roof? Can this compromise the life expectancy of your paint job? :?
splitfan
Re: Split Scream !
Post by splitfan »
John, i dont know if a reflective material on the inside would make any difference... i dunno man this is uncharted waters for me i think you would rather want to insulate the roof to keep it cool my concern is the weight of the soundproofing and im scared that if the roof heats up it may come loose and hang between the roof and the lining witch would suck big time !
Anyone have any experience with dem kinds of tings nows the time to give some advice please.
dubster
Re: Split Scream !
Post by dubster »
OMG!!!im speachless...that must be photoshop!!!just joking, awesome man...
1974 1300tp type 1
kart kraft 1717cc buggy
Re: Split Scream !
The bus looks amazing....even better than mine....well done and when we going to see it?
dubster
Re: Split Scream !
Post by dubster »
dutch yours wil look just as good if slam it put it on some fuches...man you gotta love fuchs!
1974 1300tp type 1
Re: Split Scream !
Wow, havent visited this thread for a while, the bus is looking stunning! Cant wait to see it with all the trim on. Well Done.
johanb
Re: Split Scream !
Post by johanb »
Very Nice.. The standards are high for rebuild "Splits" on the forum.. I like :-)
Bad Ass Bob
Re: Split Scream !
Post by Bad Ass Bob »
any up dates on SPLIT SCREAM ?? :shock:
johanb
Re: Split Scream !
Post by johanb »
Splitfan.. Any new updates on an awsome bus?
Re: Split Scream !
Hes keeping us in the dark MMMMMMMMMM
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Re: Split Scream !
Post by bugspray »
That is an awesome ride mate. Super. Aaaaw. Hows about you gimmie some of your vibraseal. I want to deaden my doors and quarter panels. Yeah you right, don't use it on the roof. It is heavy, and sometimes has the propensity to come loose under heat. Rather get that foam you talking about. Preferably white. It will insulate the inside and also kill the sound of rain and wind. You will have to put it on in squares using a good quality genkem like glue. Do not shirk on that.. The foam is excellent without adding weight. It also makes a good cushion for when you do a hoodlining. If you're creative enough you can emboss SPLIT SCREAM into the hoodlining. Im no pro. But I have used foam insteada dynamat.(cant afford to cover all areas with it). My R5 worth. I do expect R4,98 change thank you. Haha
splitfan
Re: Split Scream !
Post by splitfan »
Hi guys, thanks for all the info and intrest i have been slowly but surely getting on with the bus but waiting for some parts via Rui those should be here in the next week or two and i can then start pushing again to get it done all the major work is done all thats left to do are the three major things witch is the wiring , interior and then the engine with all the plumbing that goes with that ! im leaving for Namibia at the end of the week so hope to have some new pics up the week after that !!
johanb
Re: Split Scream !
Post by johanb »
Must admit,, I read better with pictures :-) Keep going mate.. almost there :-)
splitfan
Re: Split Scream !
Post by splitfan »
SO..... As you all know winter is probably the least productive time when it comes to "stayin busy in the garage"
I have done some bits and bops on the bus but i thought id show you my ultracool brackets i made to hold my mirrors to the stalks ! :mrgreen:
The mirrors,they still need the "mirror part"
