The place to ask your "Stupid Questions" thread!!
Sambabus
Short Block
Has thanked: 39 times
Re: The place to ask your "Stupid Questions" thread!!
Post by Sambabus »
Tom Bishop wrote:Something I want to Know.
Behind goods trains you see cylindrical carts being pulled. Some are V’ed, in the middle, to the ground and others to the sky.
Why?
Liquids fill and empty from the top while powders and thick slurries fill from the top and drain from the bottom(liquid is easy to pump out),....it also has to do with the clients storage facilities,subterainian storage tanks or tanks on the surface.
CTBUG
Post by CTBUG »
Okay so i've been driving for a while now... but i've always used other peoples cars... so I know what petrol THEY use...
I have a 1972 Beetle 1600... what petrol am I supposed to use? LRP or Unleaded?
Cheers
do a search, we have enough info an that question.
In short, unleaded
Has thanked: 235 times
CTBUG wrote:Okay so i've been driving for a while now... but i've always used other peoples cars... so I know what petrol THEY use...
Cheers
The best fuel for an aircooled VW, is a cocktail, consisting out of the following:
20 parts of LRP with 12 parts of Unleaded
Add one part of diesel, for valve seat lubrication (substitute with 2 parts of pure sunflower oil if diesel not available)
Add one and a half part of illuminination parraffin or lamp oil (aeronautical parrafin, or 'jet fuel' not suitable though)
Add 3 moth balls, for a slight increase in octane
.....and stir well (don't shake in mixer) :wink:
Hloni
Has thanked: 14 times
Post by Hloni »
I've been gooing in 1 part disel for the last 2 years. Baby is running smooth.
Would I pass COR with moth ball smelling fumes? How many grammes should each ball weigh?
3011
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Post by bugspray »
You know! 1 day im gonna take this thread seriously, and when my car goes kaput. Im coming for you guys!!
Been thanked: 21 times
Post by Ron&Gill »
Won't the moth ball have a problem getting through the idle jet? Or will it go through the power jet when I accelerate? Should I grind the mothball to powder, if so, what grade?
I don't anticipate any problems with the mothball passing through the mechanical fuel pump because I have an electric fuel pump and the body diameter is bigger...
Post by Ron&Gill »
vader wrote:Why do seatcovers wear skirts with slits up to their hips and then walk around the whole day holding it closed?
Why do seatcovers wear low v-neck tops which makes their boobs hang out and then get mad at you when you look at them?
Mary had a little skirt
With a slit right up the side
And everywhere that Mary went
The boys could see her thighs
Mary had another skirt
With a slit right up the frunt
But she didn't where that one very often...
Here's to the breezes
which blows thru the tree'zes
lifting little skirts above young girls knee'zes
Which pleases and teases
the older men which give them diseases
O Jesus
:drunks:
Dirk
Post by Dirk »
R and T
Enjoying each other's company
Taking pleasure in prosed perversity.
:twisted:
`68 Beetle
`66 Fastback
'90 Sunpacer
Along will come Vader
Casting his eyes on these verse
With a reputation of being a spader
And making matters worse
Has thanked: 19 times
Why the F2ck did it take me 5Pages to post here :lol:
Post by Ron&Gill »
I woz gonna hijack HR's thread, but since I'm such a nice oke...
That heater pipe that he's on about, on his inlet manifold... Is that just a pipe? Is there nothing inside it? How does it flow since it goes from one exhaust to the other, how does the flow go?? To-and-fro??!? How does it actually heat the manifold?
I still think it's just there for holding the inlet manifold upright and to stop your carb hitting the cooling shroud everytime you accelerate!!... :lol: :lol:
You're right Ron,it has 2 functions.One is to stabelise the manifold and hold it in place,and the other is that the pipe conducts the heat and so warming up the manifold.It was designed more for colder places where it usualy snows.
Post by Ron&Gill »
Ron asks: How does it work? 8)
Chris answers: You're right! :roll:
WTF?? What did you get for father's day? Boom? :mrgreen:
