How do you drop a bug?
Nathaniel
What model do you have?: 1971
Re: How do you drop a bug?
Post by Nathaniel »
Hi Bugger, can you please also pm me with the price?
Ok here is the Buggers special for the Month of July
Instead me PM every one that is interrested here is the casting for all members to see
Front beam Adjusters the selector drop type is R185 @ and this is a give away price for a selected time only
PM me if you need and I will order them
Or SMS me
Post by 1972 »
Put adjusters up front then in the back go one outer spline,two will cause your tires to wear unevenly if set rite at one outer in th back it should look like this ......v.......
YvaneS
What model do you have?: :)
Has thanked: 11 times
Post by YvaneS »
Thats exaclty what i want!
Lol looks like this thread i started is bringing some business in ey Bugger? how aBout some discount or commission?
I'l give you a call bugger
vader
Post by vader »
Bugger wrote:Ok here is the Buggers special for the Month of July
Or SMS me
For this month only and for a limited time... If you order now I (Bugger) will have two, yes two extra Jack & RedBull's with every suspension ordered... :drunks: :drunks: :drunks: :twisted:
YvaneS
Post by YvaneS »
if thats the look you going for you are going to have to fit a narrowed beam aswell , and that has problems too, it reduces the cars turning circle .
I too like that look and thats the route im taking i can live with the drawbacks
Where do I get this? and how much...
Bugger please PM me your banking details for the deposit like we arranged
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Post by bugspray »
How much to courier a beam up to jhb? Anybody know?
ZeroAxe
Drive Train
Post by ZeroAxe »
bugspray wrote:But then the fender gap is still there and huger than standard.
Indeed, but that wasnt mentioned as a problem in the first post :mrgreen:
Why dont you just take out some leaves?? $ = 0.00
VW Enthusiast
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
One bag of cement R65
For a total of R260 and 2 minutes I can also make your bug like that This special will run untill all the cement manufacturers in SA is found guilty of price fixing and then the price will be even higher
IMPI wrote:One bag of cement R65
:lol:
Well said Armand!
bugspray
Floorpan
Post by bugspray »
Hmmmm you know... the cement does work. it also aids as a stabliser for highway speeds.
Been thanked: 98 times
Portugal
Post by calooker »
Don't laugh :lol: I've seen it before. :shock:
YvaneS
Post by YvaneS »
Ok all jokes aside... Where can I get one of those narrowed beams, and how much do they go for... I dont care about the fact that the'l be a gap in the fender... because as my car stands now i'f I drop it say 2" the tire will catch on the outside of the fender .. so I want the wheel to be inside.
Uhm.... didn't you read Bugger's posts up there? ^^^
...narrow.....beaaaaammmm........
bugspray
Floorpan
Post by bugspray »
A Narrowed beam is whe the og beam is removed from the car, stripped and cut top and bottom in order to weld in adjusters (avis). its preferable to add adjusters top and bottom. this DONE PROPERLY will result in a +- 2" drop in ride height. if you are running og 165.R15 wheels you already have issues with the tyre rubbing on the inside arch. but is still doable. its worth the small price, and if like me you going to be using 195.55.R15 wheels it looks schweet.
