My '70 Lowlight SC
Re: My Lowlight SC
Thanks Gary.
- Michaelm
- What model do you have?: 1973
- Facebook: mike.marais
Re: My Lowlight SC
Sorry to hear about that Chris, thats just a string of bad luck! Things will come right.... Thats all I can believe, I think thats why we love these cars so much, they break we fix them. Seems to be a connection of some sort....Good luck bro!
- 1972
Re: My Lowlight SC
1972 wrote:Chris wrote:Towed the SC!![]()
Chris just dont make the toyota engine number 4 please
Im gonna keep my mouth shut from now on...
- Dutch_Diver
Re: My Lowlight SC
Chris, Can you get a motor down to Jurgen for him to see what's happened?
Re: My Lowlight SC
I'll have to send it by truck.
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
Re: My Lowlight SC
Until uncle Chris gets to the bottom of all this, I'm gonna hire a Piccanto and park Ol' Betty in the garage! Serias, what is all this uncle Chris?
Bad Ass Bob
Re: My Lowlight SC
BABs fuel pump blanking part for Chris !!!
just another some thing !!
Re: My Lowlight SC
After some consultation with Impi,TonyZ and Bugger,we came to the conclusion that the main culprit is cooling.
I fixed at least four problems.First thing I did was got the tin behind the fan shroud that goes on the firewall as the Beetle is more rainbow shaped and the Bus' is more square.Bob took it to work and had to cut a hole in it where the oil cooler duct goes through.
The oil cooler duct was the second thing that was missing.I found a fanshroud with the complete oil cooler tin and made sure that the all holes are closed.Some good duct tape and a couple of new screws did the trick.
Impi also suggested that I replace the heater pipes to allow cool air to blow over the exhaust.
Cleaned up the altenator,replaced the old pressure plate and cleaned the oil cooler.
Then put the whole lot together and fitted it,put a seal in around the engine to keep hot air out the engine compartment.
Tony also suggested I get a cheap rev counter to check the revs.So I got one with a shift light.
BAB came over after work and helped me sort the timing and she runs well.........again.But I have to say that the engine bay stays a lot cooler.
brianj
- Single Port
- Has thanked: 13 times
Re: My Lowlight SC
Hope the rev counter doesnt see 8 too often!
Re: My Lowlight SC
I set the shifter light on 3800 revs
- Tom Bishop
- Single Port
- Been thanked: 5 times
Re: My Lowlight SC
Chris, Your problem may be you are riding your revs to Low.
