Turbine for VW
Re: Turbine for VW
From Wiki
Shaft horsepower
Shaft horsepower (shp) is the power delivered to the propeller shaft of a ship or an aircraft powered by a piston engine or a turbine engine (the combination of turbine engine and propeller commonly called a turboprop). This may be measured, or estimated from the indicated horsepower given a standard figure for the losses in the transmission (typical figures are around 10%). This measure is uncommon in the automobile industry, because drivetrain losses can be significant.
Re: Turbine for VW
In this pic it shows actually how big it is.
Strange contraption,just a pity the original Beetle was never saved.
- karmakoma
Re: Turbine for VW
Thanks Eben
made for some cool reading. Not small is it?! Those cars went like CRAZY! The ultimate resto cal accessory
Re: Turbine for VW
I had a chuckle about this quote:
only about 110 or so mph more than the stock engine could ever push the car-- at which point it, full of false confidence, takes flight.
- karmakoma
Re: Turbine for VW
- Mr9A
Re: Turbine for VW
thats the 1st time that i have seen this pretty cool but damn that thing is huge
