Sidedraughts?
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
Sidedraughts?
Why do sidedraught carbs have a reputation for pushing out more power?
What's the advantage?
As far as I understand it, the only difference is the intake is horizonatal instead of vertical?
Cheers, N.
Cheers, N.
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Because the intake charge doesn't have to make any changes in direction before reaching the inlet ports.
This is assuming they're fitted to an inline or V engine. To have the same effect with a horizontally opposed engine you'd want downdraughts.
- eben
- Site Admin
- Been thanked: 54 times
- MINCE
- Has thanked: 4 times
i have a vw mag where a dude fitted 2 sidedraughts to his motor. but then again, he had to, because he needed to make space for 2 turbochargers. oh, dont forget the enlarged cylinders heads, 8 valves a side
- Merlin
The Weber sidedraughts come up for sale fairly often, but from my understanding of Fig's reply, they're not really beneficial on an ACVW engine?
I've heard of guys using the Alfa carbs before...but why taint your 'dub with Italian rubbish like that?
Flame away...
N.
Flame away...
N.
Dont diss those carbs... they run great!!!!
- fig
- Bus Driver
- Merlin
Mmmkay.
Running Solexs on my bug soon...dual Solexs...big Solexs...Kadrons actually.
N.
N.
- fig
- Bus Driver
Oh, and re your "Italian rubbish", Merlin, early Porsche 911s had purpose designed Solex carbs, one for each cylinder. These carbs had such a bad flat spot between 2,500-3,000rpm that all early 911s prepared for racing used a pair of off-the-shelf triple-choke Webers, and from February 1966 the Webers were fitted as stock on all 911s.
- Merlin
*grin*
With the exception of Pagani and Venice, minus the tourists, I'll avoid thank you.
Flame away...
Yah, OK, OK, some Webers are decent.
N.
Flame away...
N.
- eben
- Site Admin
