Numerous engine/mechanical bits available.
Re: Numerous engine/mechanical bits available.
Dibs on any Oettinger WBX-6 engines that he may have!!!!
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Any good condition carbs for a 1600 single port? 32pict or 36pict or something that woud add alil vooma to my bug?
- Skymac
- What model do you have?: Bay window
Fig, if you buy everything, will you be selling the parts off?
Once a fanatic, always a fanatic- Skymac
Oh yes, looking for beetle hub caps
Once a fanatic, always a fanatic- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
That's the idea. Also don't want them to be scrapped or exported.Skymac wrote:Fig, if you buy everything, will you be selling the parts off?
- Dazz
- Oil Cooler
- Has thanked: 2 times
- Been thanked: 4 times
id like dual carbs for a bug please also engine tins. Also rwinport intake manifold.
Measure twice CUTonce.
1975 Kombie
1979 Kombie
W203 C320 CDI
'68 Austin Cambridge A60
Looking for a kombi project
1975 Kombie
1979 Kombie
W203 C320 CDI
mahleu
Any non-VW bits? And a price on the Webers?
Life begins at 80 and ends shortly after in a temporary court on the side of the road.
- Edmond
- Has thanked: 22 times
- Been thanked: 45 times
Does he have a std std 1600 beetle crank aso interested in a linkage for solex carbs on a bug
Does he have any high perf engine parts?
- dsan
- Twin Port
Not ignoring you all, it's all going into a monster list with your names on it, so i can respond in one big post and not mini ones
Daniel
- 1972
Early Doghouse fan shroud
Tp heads
1600cc oil cooler with contraption it mounts to.
Twin carbs (SP)
Tp heads
Twin carbs (SP)
- JamesD
- Been thanked: 20 times
Dual carbs + inlets and linkage (any, so long as they decent carbs with inlets and linkage) to fit Type 1.
Twin port tin, Original German please, good condition, Will be powder coated so good condition is mainly dent and crack free, for Type 1.
Pretty pretty please...
Thanks man.
Thanks man.
From fastest to slowest:
'75 SP 1600 with a few mods
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
Tin for 1600tp, '75. Also looking for rubbers, front seats (black or brown covers), 'glove box', carpet set, fuel pump (new unless there be a used for a beer), silicone leads.
I can come pick up I am sure.
benjamin
- Oil Leak
- What model do you have?: 1966
Any new 1300 s/p exhausts?
Also dual carbs for a single port motor and a bosch alternator.
- hitlers revenge
- Been thanked: 36 times
4ORK, you still can't read. 2 posts and 2 "I WANTS" WTF.
