Know your car
JamesD
Been thanked: 20 times
Re: Know your car
Post by JamesD »
bugspray wrote:Klippie, how much and where did you get a free flow zhorst installed, also what exactly is a free flow systen in a beetle look like?
if you recall, the Exhaust on my brothers Puma and on my Bug is a freeflow of sorts. Its what the SP's came out with as standard...
How much? think its 900 bucks or so. Where? Volkspares. Installed? Your garage floor...
From fastest to slowest:
'75 SP 1600 with a few mods
GavinHuart
Has thanked: 48 times
Been thanked: 9 times
Re: Know your car
Post by GavinHuart »
jmvv wrote:GavinHuart,
I have followed your thread on your relationship with your car and considering the meticulous care you lavish on it, I would suspect that the compression is not what it should be.
I agree that a compression test would give a true indication of the condition of the engine.
The flat spot you mention could be caused by warm air from the engine bay being drawn into the carb and upsetting the mixture. Air at 50 degrees Celsius is a lot less dense than air at 20 degrees.
I am not promising miracles, but you are welcome to pm me so we can set up an appointment for a Saturday.
Thank you so much for your response Jmvv. I do try to administer to my car the best way I know how. I find these cars very forgiving and mine usually responds positively to the slightest "calculated adjustment". I haven't got a compression tester/gauge nor the exact know-how to correctly perform a compression test. Excuses, I know :( ...Perhaps if you have one, we could try it?
Your writings on the possible cause for the flat spot sound perfectly viable in hindsight. I have attempted to adjust the mixture to precisely what was recommended according to a 1200 manual I have but don't doubt there would be a few more tricks to getting it perfect. It is old and a little weary after all. :|
I will certainly take you up on your offer if it's not too inconvenient. I'd hazard a guess at it being nearer the end of the month when I have a little more silver to cross you palm with :wink:
Again, many thanks and I'll PM you to arrange an appointment.
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Re: Know your car
Post by bugspray »
Coolios! Thanks Dubz,Klipz and James. The zhorst kinda kills the "beetle tone" right? That's the main result I'm looking for, a lil throaty and less beetleish zhorst note.
dubster
Re: Know your car
Post by dubster »
it kills the whistle sound and gives a loud thumper type sound...
1974 1300tp type 1
kart kraft 1717cc buggy
dubster
Re: Know your car
Post by dubster »
but with the right type of silincer you can get it sounding like a normal motor...
1974 1300tp type 1
Re: Know your car
dubster wrote:but with the right type of silincer you can get it sounding like a normal motor...
and with the right engine and carbs you can get it to sound rather angry and have everyone ask if its a Porsche :mrgreen:
dubster
Re: Know your car
Post by dubster »
yep that can also work...but bugspray what do mean by beetle sound?do you mean the wistle of the stock system or the sound of the motor that flat4 sound?
1974 1300tp type 1
