Clearing the wifes garage
- vfront
- What model do you have?: 1974 Beetle
- Has thanked: 3 times
Does anyone know of a club for Peugot 504 and renault 5. I have 1 of each taking up space where I could park some aircooled cars. Or if anyone wants to take these 2 off me let me know.
Thanks R15000.00 R2500.00
- hitlers revenge
- Been thanked: 36 times
Re: Puegeot 504 & renault 5
Tom Bishop or his mother could help you with both I believe. Send him a PM.
- vfront
Re: Puegeot 504, renault 5 & Toyota Corona
Also have this 1973 Toyota Corona that needs to go.......
R17500.00
R17500.00
- Klaus
- Has thanked: 13 times
- Been thanked: 11 times
I think you should donate the Renault 5 to the next KKK Kamp Out for use on the bon fire
- vfront
We can always teach it to fly off Krugersdorp Hill........
Or cut it up into a fire pit for the new bar????
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
I have no idea what the frenchie who came up with some things on a Renault 5 was smokin !
I had a girl who owned one (probably why we split up
) You have to take the spare wheel out the engine to see what the hells wrong with the piece of frog leg crap and dont think you have any chance of leaning up against it ! They put the frigging exhaust in the front fender !!...Ohh the total joy of not owning one of those !!
- vfront
Re: Clearing the wifes garage
The Mrs has also asked me to sell her "aircooled" 2007 Jonway Laguna 250cc (600km)
R10000.00
- vfront
as far as I know it is running, just needs some fuel and a battery.
Will see if I can get it started this week.
Everything in life is negotiable, its just to what extent. PM me an offer and we can talk
- Watercool
- Been thanked: 6 times
Do this with the Renault 5 (Le Car)
- Been thanked: 98 times
Try do a clutch on a Renault 5, virtually the whole front end needs to drop out ie: front suspension, tranny & motor ??
- zubz
- What model do you have?: 62 LHD Rag, 69 Auto
I wonder if it would be the same when servicing a french ladycalooker wrote:Try do a clutch on a Renault 5, virtually the whole front end needs to drop out ie: front suspension, tranny & motor ??
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
BTDT. Changed a starter motor on a R5 once; never again. You have to pull the trans to remove the starter; you can't just remove the trans because of a chassis crossmember directly in front of it, hence having to remove half the front end.calooker wrote:Try do a clutch on a Renault 5, virtually the whole front end needs to drop out ie: front suspension, tranny & motor ??
After that experience I will NEVER buy a Renault of any description.
BTDT. Changed a starter motor on a R5 once; never again. You have to pull the trans to remove the starter; you can't just remove the trans because of a chassis crossmember directly in front of it, hence having to remove half the front end.fig wrote:calooker wrote:Try do a clutch on a Renault 5, virtually the whole front end needs to drop out ie: front suspension, tranny & motor ??
After that experience I will NEVER buy a Renault of any description.[/quote
Ever tried to change a head light bulb on a new Renault? It's like a 2 hour job
- louisvr45
I have heard when changing a fanbelt you have to losen the one suspention part and the do wheel alignment again
