gearbox repair
Grumpy
What model do you have?: 1978 varaint 411 L
gearbox repair
Post by Grumpy »
i need info on gearbox repairs to a variant 411 L. It apparently has the same box as the kombi. Please help with detail how ton strip and assmble.
Re: gearbox repair
Speak to Bugger,I'm sure he can help you out.
dsan
Twin Port
Re: gearbox repair
Post by dsan »
seconded, send it to mr gearbox, Pierre "I've put more gears into slots than a porn star has had <censored>" Bugger
Daniel
Has thanked: 19 times
Re: gearbox repair
Grumpy wrote:i need info on gearbox repairs to a variant 411 L. It apparently has the same box as the kombi. Please help with detail how ton strip and assmble.
If aparantly it has the same as Kombi it has been replaced a 411 has a different spline spigot shaft than Kombi beetle ghia etc
How does the transmission look underneath? Does it look like a auto type box with a flat type of oil sump ?
More info or Any pictures so we can first determine what box you got
Where are you in SA
Re: gearbox repair
I have a 411 woprkshop manual for you if you want, R150. PM me if interested.
And don't forget to introduce yourself in the relevant thread, as per your introductory email.
