Guess what I'll be doing the weekend.
- hitlers revenge
- Been thanked: 36 times
!@#$%%$#$%^%^% Took mine down to the harbour to get covered in Soda Ash !@#$%^^^%$#^$%#
- lowlight
- Been thanked: 14 times
Got a valve to make a pin for the fuel pump for my beetle.
Couldn't find a buyer for the project so it's on again
jmvv
- Been thanked: 24 times
Put Petrus on the stretcher and towed him to Vee Motors, so they can sort out the following issues under warranty:
Burnt valve on no 4
Oil leaks - third attempt (He piddles like a Jack Russel puppy)
Loss of oil pressure as engine warms up - caused by second oil leak attention attempt.
I know that I will eventually rebuild the engine myself, but a warranty is a warranty...... and sofar they have been very decent about the issues.
PS:
Sofar I haven't tossed my toys out the cot. Maybe it's too cold to get angry.
Burnt valve on no 4
PS:
make up your mind please....Blitzkrieg wrote:Couldn't find a buyer for the project so it's on again
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
Thought since I am in GP I should maximise and visited VS Jetpark and got Ol' Betty a set of Bougis and tapet cover gaskets.
Can't wait to install the Bougis next month when I get home.
Thanx Martin for the service.
The bearded man.
The bearded man.
- CooP
- Clutch
- What model do you have?: '71/72 Hybrid Westy
- Has thanked: 13 times
Finally finished off the filling in of the (unused) left-hand sliding door handle. It's gone from this:
Which warped a lot of the door when it was welded, even though we just did a bit at a time to try and avoid overheating it. I have been laying on lots of thin layers of filler every day after work and then block-sanding them back again. During this laborious process:
And it is now looking like this:
Also made a start on the mess that is the front end, pics to follow. Whew, time for some
Size does matter
- BUSBFK
- What model do you have?: 1965 Type 2, Kango
I changed the thing between the gear shit rod and the gear box on Flossie now her gear change is nice and tight again.
Flossie 1965 SPLITTY http://www.aircooledvwsa.co.za/viewtopi ... 75&start=0
1976 Bug
Kango T-Top Buggy http://www.aircooledvwsa.co.za/viewtopi ... 23&t=19315
1976 Bug
Don't worry this time I'm decided and sticking to my gunsTony Z wrote:make up your mind please....Blitzkrieg wrote:Couldn't find a buyer for the project so it's on again
- CooP
- Clutch
Gear shit rodBUSBFK wrote:I changed the thing between the gear shit rod and the gear box
That's what it should be called
Size does matter
- BUSBFK
Yes shit rod.CooP wrote:Gear shit rodBUSBFK wrote:I changed the thing between the gear shit rod and the gear box![]()
1976 Bug
1976 Bug
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
I guess it is what it is , although not perfect its a once off and therefore a "Marmite" moment you either like it or you dont
- dsan
- Twin Port
about to set fire to this bug. Seriously I will never buy parts made in brasil again. They are so poor in terms of quality and build, you are wasting your money. piece of s*** f*** wan*** carb now will not disable the choke, so it runs like s***.
worked fine all week but the day I really need it, it happens.
bah!
bah!
Daniel
I am sure you said that last time....Blitzkrieg wrote:Don't worry this time I'm decided and sticking to my gunsTony Z wrote:make up your mind please....Blitzkrieg wrote:Couldn't find a buyer for the project so it's on again
- hitlers revenge
With the Help of Ron (all they way in PNG) I pulled one of my busses reduction boxes apart. Are they supposed to be full of grease? Why then have they got Oil fillers and drainers?????????
Removed the barn doors and serviced the hinges. In the process loosing one of the plates which the countershunk bolts bolt onto. The plate fell down the vertical channel. Had to cut a hole in the channel and make up a new plate. !@#$$%^%%$##@@
